Old 04-25-2010, 07:53 AM   #1
1965 20' Globetrotter
Bromsgrove , Worcestershire
Interior Rivets '65 GT
I've started the teardown prior to replacing the floor in my '65 GT, now I'm starting to run into Rivets that need to be drilled out in the interior panels. I don't want to screw up and enlarge the rivet holes if at all possible, what drill bit size should I be going for?
Chiefy is offline   Reply With Quote
Old 04-25-2010, 08:23 AM   #2
There are 3 drill bit sizes that are used on Airstreams.
#30, #21 and #11 are those sizes.
The #30 is used for 1/8 inch rivets, as used on the inside of the coach. That same size is used to drill out the buck rivets, on the outside.
The #21 is used when Olympic rivets will be installed.
The #11, is used for 3/16 inch rivets, such as used for the underbelly.
Old 04-25-2010, 08:24 AM   #3
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Time to do a little searching!
Honestly, there is more on this forum about rivets, installing and uninstalling, (drilling out) than you will ever want to know.
I have used 1/8" bit to drill them out and can re-rivet with the same size. If the hole becomes enlarged just up the rivet size.
But really, search, it will pay off. Pay special attention to Aerowood and Zepellinium, they both have detailed posts about the subject.
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 04-25-2010, 01:16 PM   #4
Thank you for your responses guys.
I did search the forum but given the wealth of knowledge and the wide variation of applications I figured it better to ask a direst question. Certainly not laziness!
Also, being based in the UK means if I screw up, replacement parts are a long way off.
Interior rivets in a 59 caravanner jeffinwnc Ribs, Skins & Rivets 3 10-17-2009 11:25 AM
Popped Interior Rivets - 1962 smcpheters 1960 - 1963 Flying Cloud 17 07-05-2008 12:44 PM
'63 trotter popping interior ceiling rivets ChicknKathy General Interior Topics 13 05-01-2008 03:41 PM
Popping Interior Rivets in Maine!! 65Toaster On The Road... 6 06-16-2007 03:41 PM
interior panel rivets j54mark General Interior Topics 4 03-17-2003 09:31 AM
