Old 08-30-2014, 04:59 PM   #1
2005 30' Safari
Bothell , Washington
Interior rivets
2013 flying cloud 23D.
Noticed two missing rivet heads inside the trailer. What is the correct replacement rivet and is one rivet gun better than another ?
Chuck
charlesk is offline   Reply With Quote
Old 08-30-2014, 06:11 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
You will need to drill out the body of the old rivet, using a #29 bit. Be very careful not to make the hole bigger...start the drill at a low speed centered on the old rivet...it may spin on you...you just have to work it until it comes out or drops through the other side. Then you can replace the rivet with a 1/8 inch blind or "pop" rivet. Most any good grade rivet gun from the big box store will work. I would not use their rivets however. You can get a bag of rivets from places like vintagetrailersupply.com...and always have them on hand.
arktos55343 is offline   Reply With Quote
Old 08-30-2014, 06:40 PM   #3
aftermath's Avatar
Spokane , Washington
Bingo. An easy fix if ever there was one. I use an 1/8 inch bit, 1/8 inch aluminum rivet and my dad's old pop rivet tool. Pretty easy.
aftermath is offline   Reply With Quote
Old 08-30-2014, 06:52 PM   #4
2005 30' Safari
Thanks. Just what I needed.
Chuck
Old 08-30-2014, 06:54 PM   #5
Chuck
Airstream work requires 3 different numbered drill bit size, for doing first class work.
# 30, # 21 and # 11.
Any size over that will guarantee poor workmanship.
The factory drill bit for a 1/8 pop rivet is # 30.
# 30 drill bit is .1285 or 3 1/2 thousands over a 1/8 rivet.
# 29 drill bit is .136 or 11 1/2 thousands over a 1/8 rivet.
As you can see, the # 29 is way to large to do anything except a sloppy job that most likely will fail in a very short time.
Old 08-30-2014, 09:10 PM   #6
Central , Mississippi
Some pop rivets have a steel shank, don't use these.
Fastenal has a good selection and great prices if you buy in bulk.
1/8" Dia .063-.125" Grip Range AB42A Aluminum Rivet - W/Drill Bit
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-31-2014, 12:01 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Be sure you have a positive depth stop on the drill bit before you try to drill out a rivet. I use a wooden block.
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
