Hey guys, i have removed my interior panels to replace the insulation and make a couple other repairs.
are there any alternatives to riveting the panels back on?
dry wall alternatives, panel alternatives or something like that?
mind you, i have an Argosy where the walls have some curvature, flexibility is a must.
Some have used 1/8in plywood….some real nice jobs too.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
1966 17' Caravel
Las Cruces
, New Mexico
One word: weight. The frames and axles are designed for a maximum weight with the trailer ready to go camping. The frames are not known for extreme rigidity, either. They have to flex while towing. What you are talking about adds quite a bit of weight to the unit.
1966 Airstream Caravel
2006 Toyota Tacoma
no problem with rivets, just never used them before. youtube makes it seem pretty easy to install. this weekend i shall get my hands on rivets, any tips of what not to do or things to avoid..?
