Old 02-03-2015, 09:49 AM   #1
Castaic , California
Insulation
How does the insulation on a 25FB airstream hold up on a hot summer days? Does it get very hot inside the trailer?
24brem is offline   Reply With Quote
Old 02-03-2015, 01:42 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums.
Airstreams in general have relatively thin walls (~1.5"), single paned windows and aluminum interior and exterior skins linked together with aluminum ribs. So it isn't just a matter of the insulation in the walls, it is all the other design features you have working against you that makes these trailers not-so-well-equipped for extremes of temperature. So yes, if you park one in the sun, it warms up inside, if it sits in the cold of winter, it gets cold inside. They are kept comfortable mostly through brute force., ie a big air conditioner or a stout furnace.
good luck!
Old 02-03-2015, 02:32 PM   #3
Old 03-06-2015, 12:26 PM   #4
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Has anyone drilled small holes in the walls and, using canned foam, filled the walls?
choctawmel is offline   Reply With Quote
Old 03-06-2015, 12:29 PM   #5
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Don't do it. I tried that with the floor of a boat once... That expand-a-foam bulged the floor of the boat up about six inches. I had to cut the floor out, dig out all the foam, and re-fiberglass it. It will bulge your walls like crazy. Also, most of it is open cell, which means that it absorbs water... Another feature not good in boats or Airstreams.
-Red, learning lessons the hard way...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 03-06-2015, 05:31 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi 24brem, you have a good question. As Begeledhel said, our aluminum trailers conduct heat and cold very well. Kinda like aluminum cookware. New Airstreams have a reflective paint on the roof skins that does help. Awnings also help keep the trailer a bit cooler. A good AC helps keep things comfortable.
Maybe you will find one you like.
David
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
is the insulation flammable ? oldvws General Interior Topics 3 12-31-2002 11:12 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
