Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-19-2009, 05:02 PM   #1
1973 31' Sovereign
edwardsburg , Michigan
installing new panels
Hello, installing new panels on front corner of our as. Would like to know what type of sealent is recommended when riveting the panels together.
Marcy
slvrbulit is offline   Reply With Quote
Old 02-19-2009, 08:57 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Vulkem is the choice of most people as it has a long set time allowing you time to get the panel placed and riveted before it drys out. What kind of riveting are you using? If Olympic rivets, dip each one into the vulkem to help seal them.
Check here for vulkem Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 02-20-2009, 03:07 AM   #3
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
The name has changed from Vulkem to Trempro. Same stuff.
Zep
Zep@Charmedquark.net
Old 02-20-2009, 04:50 AM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Zep, in Canada It's called Trempro Vukem on the tube. Maybe old stock, but it still works fine. I found it for sale at the local Fastenal store.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Old 02-20-2009, 04:54 AM   #5
Baltimore , Maryland
And now to open the debate flood gates.....
I personally recommend you DO NOT do a structural (exterior panels are structural) repair using Olympic rivets. That is not their intended use. You should be using solid rivets that are bucked into place.
And now someone else will chime in and say other wise.
Old 02-20-2009, 06:14 AM   #6
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
I recently discovered that my Airstream features a front panel replacement and whoever did the job used olympic or field rivets. I ended up leaving them in place as they seemed to be doing just fine. You know what they say... "If it ain't broke, don't fix it" I did apply some sealer to inside of the seams just for good measure.
I think issue is that eventually the Olympics will leak?
Torii is offline   Reply With Quote
Old 02-20-2009, 06:23 AM   #7
Airstream approved the use of Olympic rivets, without washers, for structural repair back in 1972.
The Olympics took the place of "explosive rivets" that were made by Dupont, who took them off the market.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-20-2009, 08:24 PM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Good thing the explosive rivets are no longer used. I took apart a 58 trailer that had the whole side replaced with them and every one was loose and leaking.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Old 02-20-2009, 10:17 PM   #9
The explosive rivets "could" do a good job, "BUT"............
Like anything else, ya hadda be careful.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-21-2009, 04:01 AM   #10
Now see what I told you all... it has become a rivet debate.
Okay for starters, the olympic rivets were approved in the early 1970's due to the work by some Airstream Insurance agents pushing for it. It makes total sense to use them, for they save on time and labor of removing the interior. There has been a history of making changes to make the line between lost money and profit thinner. Just because it was approved does not mean it works. Thelidomide was approved to treat women with morning sickness and because of it a generation of deformed babies was born. Just because something is approved does not make it right.
Once again, do it correctly and buck those rivets....
Old 02-21-2009, 06:48 AM   #11
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Frank, it takes two to have a depate and I don't see anyone argueing against the fact that buck rivets are better only that olympic rivets have been used for over 20 years and I have not heard of any panel falling off because of their use.
I replaced 2 panels on mine and I used Buck rivets because I could. I use Olympics for repair jobs and patches where it's not practical to strip out the insides for bucking.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Old 02-21-2009, 07:47 AM   #12
Caravanner Insurance did not push for Olympics.
The fact is Dupont stopped making explosive rivets.
I personnaly called them and offered, on behalf of Airstream, to buy a couple of million of them, if possible.
Dupont said "NO". They are taking them off the market, period.
It was then necessary to find a satisfactory replacement.
Be as it may, the very first Olympics that we had, were not very good. They were short lived.
In short order then, the Olympic rivet as we know it today, was born.
It does work very well, when properly used. There's that "proper" word again.
Obviously, buck rivets are superior, but it's not always practical to use them.
Andy Rogozinski
Inland RV Center
Corona, CA
solar panels jerrypeterma Generators & Solar Power 7 08-25-2008 08:05 AM
Bleaching Panels Aluminati Upholstery, Blinds, Walls & Interior Finishes 2 12-17-2007 02:52 PM
Installing stainless steel wall panels mcneon Cabinets, Counter Tops & Furnishings 25 04-13-2007 04:48 PM
Under Panels jperryfly Belly Pans & Banana Wraps 31 06-30-2004 09:35 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
