Old 02-01-2011, 08:56 AM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
Inside corrosion of outside skin
After removing the interior I can see a spot of corrosion on the inside of the exterior skin. What can I do to stabilize it? Paint? I seems to be the air conditioner that might have caused this. It is right next to the roof support by the air conditioner.
Ed/Breadbug
ID:	121140   Click image for larger version
Breadbug is offline   Reply With Quote
Old 02-01-2011, 09:53 AM   #2
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Clean it up with a wire brush and then apply alodine and alumiprep from http://www.aircraftspruce.com.
FC7039 is offline   Reply With Quote
Old 02-01-2011, 10:05 AM   #3
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Thank you so much.
Ed/Breadbug
Old 02-01-2011, 10:09 AM   #4
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Ed/Breadbug
Hi Ed;
From what I can tell from the pic it appears to be rusty in color. If that is the case you may have to carefully inspect the AC. Corroding parts in AC can track the molecules of steel carried by moisture along your skins. In any event the moisture appears to be the culprit. Remove loose stuff with sandpaper. Wearing face shield protective clothing and gloves spray affected area with Aluminex By Marykate. This oxidation remover should be available in your local boat stores. While wet wire brush the affected area with Stainless Steel [only] brush until clean. Wipe down several times with soaked in warm water rag. Neutralize the surfaces with Alondine design for aluminum surface prep. Paint with suitable aluminum primer. What is important that you eliminate rusty parts in AC and stop the leakage. Thanks, "boatdoc"
boatdoc is offline   Reply With Quote
Old 02-01-2011, 10:37 AM   #5
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
From the pics it does look rusty in color. In person, the color is more of a dark blueish grey to whitish.
Ed/Breadbug
1975 Tradewind gut and remodel. Breadbug 1970-79 Tradewind 72 01-16-2013 10:20 AM
Cable jack options for exterior skin NicheVintage Audio, Video & TV 8 01-30-2011 06:20 PM
Show Me Your Wheel Well Patches skittles Wheel Wells 5 01-20-2011 06:26 PM
Corrosion Kirbys Ribs, Skins & Rivets 4 01-19-2011 06:39 PM
inside ceiling rivets lsrart1 Ribs, Skins & Rivets 1 01-17-2011 05:53 PM
