Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 01-17-2011, 05:15 PM   #1
Summerville , South Carolina
inside ceiling rivets
What size rivet should I use to replace a missing one in ceiling of a 07 27fb Safari?
lsrart1 is offline   Reply With Quote
Old 01-17-2011, 05:53 PM   #2
1963 28' Ambassador
Northern VT , Vermont
Dictated by the size of the existing hole. Probably 1/8 inch dia. If the hole is oversized 5/32. Use only all Aluminum rivit including the mandrel [nail]. Grip length is important to get a clean break off inside the compressed rivit. If the rivit is to long part of the mandrel may stick out after break off, ugly and sharp. Usually 1/8" grip lenght for two sheets of aluminum only, longer if its where the skin is attached to hull frame. You can get all alum rivits in various colors for interior work.
putback is offline   Reply With Quote
Earning Rivets and such tvanwave Forum Admin, News and Member Account Info 10 06-07-2011 04:33 PM
Stainless steel screws instead of rivets? Lothlorian Ribs, Skins & Rivets 33 03-22-2011 11:22 PM
Loose interior ceiling Bandits Ribs, Skins & Rivets 5 01-12-2011 05:05 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
Hole in ceiling Brianv512 General Repair Forum 2 01-08-2011 06:24 PM
