Old 09-18-2008, 10:52 AM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
If/When did AS change from one piece ribs?
I tried to search for this but only found a few mentions in other subforums.
Do "newer" airstreams no longer use a one-piece rib? If so... any idea when Airstream did the tranistion to no doubt the less expensive assembly?
Ron
ronstory is offline   Reply With Quote
Old 09-18-2008, 11:32 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Cut costs, Raise price, or ship it to be made in China.... Seems to be the way things are going.... companies are getting greedy, How much do they really need to make.......???
Most of us get by with one house of moderate means.....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-18-2008, 11:55 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It was supposed to be changed with the introduction of the wide-body coaches. The wide body has a very different radius across the roof than the non wide body applications, so the ribs had to be produced as a 3 piece assembly.
Old 09-18-2008, 01:41 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
This would be a great question for Fred.....?
I too would like to know!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 09-18-2008, 02:11 PM   #5
_
Originally Posted by ronstory View Post
...Do "newer" airstreams no longer use a one-piece rib? If so... any idea when Airstream did the tranistion to no doubt the less expensive assembly?
yes, they are now 3 pieces.
actually the side and top rib sections and channels are "skinned" together with the outer panels, taped and riveted...
then the top, sides, and end caps are assembled into a shell.
so the shell is really 5 segments combined into 1, before mounting onto the floor/frame assembly.
the jigs used for the 3 semi flat sections are MUCH easier for workers to build on...
they can essentially stand or use short ladders and work without bending over much or in other odd positions.
this started around the wide body transition and really the REVISED curve/radius, but not exactly all at once.
there is NO suggestion ANYWHERE that this has to do with IMPORT of parts or that it's LESS expensive (which may be true)....
a/s CLAIMS using this technique is STRONGER than the previous approach with continuous one piece ribs...
a key part of this transition was the design of different RIB profiles, C channels, joiner bits, and other cad designed small parts...
but i don't buy the strength claim and others don't either. but the a/s engineers say otherwise.
an a/s assembly really is NOT semi-monocoque any more.
instead it is 5 fabricated sections, connected then mounted 2 a frame/floor/running gear unit.
i've posted detailed close up pictures of the 3 piece ribs, lower channels, skin and how they are joined together in past threads...
will dig 'em up later.
cheers
2air'
Old 09-18-2008, 03:39 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Seems to me there were a couple of pictures over on TheVAP.com website a year or so ago, as well.
www.nesa.org
Air No. 6427
Old 09-18-2008, 05:24 PM   #7
1994 30' Excella
Mississauga , Ontario
Mine is a 94. It has the wide body roof profile but is still only 8 feet wide.
In 95 they increased to 8foot 6 inches.
Mine has the three piece frame.
Al
Old 09-19-2008, 01:03 AM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Folks, thanks for answer and opinions. So basically any AS with a new roof profile will have the multisection ribs. and that sound like it started in the early nineties.
Did I miss anything?
Ron
Smoked ribs Hawkeye5 Stella's Kitchen 10 05-18-2008 10:29 PM
How wide are the ribs in a classic motorhome guy99 Classic Motorhomes 2 02-27-2006 01:24 PM
No Ribs in front & rear??? BornToRock Ribs, Skins & Rivets 0 08-28-2005 09:20 AM
oh my aching ribs desi arnaz Ribs, Skins & Rivets 7 07-10-2005 11:27 AM
Replacement ribs crgintx Ribs, Skins & Rivets 5 01-16-2004 12:27 PM
