Old 03-31-2008, 05:40 PM   #1
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Ice in exterior seams
Has anyone delt with exterior panel seams expanded by ice? Found an early '60s I'd like to restore, been out side awhile, some seam leakage through to the interior. Right now with the spring freeze/thaw you can see ice is expanding some overlaps. Could they be "streched" beyond repair? She's a little sweetie, I'd like to save her!
putback is offline   Reply With Quote
Old 03-31-2008, 05:46 PM   #2
Mrs_RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Not my area of expertise but I'm betting those "in the know" here on the forums might be able to more easily answer your questions if you could supply a few pictures of the areas for which you are concerned.
Mrs_RedSHED
Mrs_RedSHED is offline   Reply With Quote
Old 03-31-2008, 05:59 PM   #3
Don't worry about the ice.
That's why the seams have considerable overlap.
If ice indeed caused leaks as you describe, then there would be at least 100,000 Airstream trailers and motorhomes, with the same problem.
That is not to say you cannot have water leaks, but not likely from ice.
Old 03-31-2008, 07:44 PM   #4
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Andy just a quick shout out to you, Thanks for all of your good old school advice. Robert
bertro is offline   Reply With Quote
Old 03-31-2008, 09:02 PM   #5
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Ice in the seams? If you can add photos that would help. Better yet, tell me the location of this frozen forgotten one with stretch marks and I can check it out for you.
safari62 is offline   Reply With Quote
Old 04-01-2008, 02:39 PM   #6
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Darn it safari 62, now where did I misplace that trailer! Thanks folks, May not have ice pics, serious warm up right now. Been following A.S. forums quite a while, learning. Was hoping for advice from someone like Andy. Told me just what I'd hoped to hear. Any and all advice is welcome. Waiting for the end of "mud season" to bring her home.
Old 06-26-2008, 01:24 PM   #7
1975 31' Sovereign
creston , Iowa
do the rivets leak? how do you seal them?
johnb1 is offline   Reply With Quote
Old 06-26-2008, 01:27 PM   #8
1975 31' Sovereign
creston , Iowa
andy,how do you seal rivets that leak?
Old 07-06-2008, 12:01 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Guess it depends on the rivets and what sort of access you have to them.
The real question is whether the rivets are the cause of a leak or just a result of an exterior seam that needs to be resealed. Are the leaking rivets "interior rivets"? If so, I'd venture a guess that you have seam leaks from the outside which allows water between the two skins...then the water is coming through the interior pop-rivets. The rivets do not go all the way through from the exterior to the interior...and the interior rivets shouldn't need to be watertight if the exterior skins are sealed properly.
On the other hand, if the exterior rivets had washers that have deteriorated away or are just loose, I would say, drill them out and replace them with new Olympic rivets, each dabbed it a bit of vulkem when re-installed. Or if the rivets are still tight and you have access to the back side of them, just dab the vulkem on the backs...this is assuming the interior panels are removed.
Shari
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Parbond or Gutter Seal for Exterior Seams??? mwmoss Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 02-23-2005 08:36 AM
Ice! 59toaster Off Topic Forum 30 02-04-2005 02:39 PM
Ice anyone? eljay Off Topic Forum 7 01-06-2005 02:55 PM
Split awning seams APB Awnings 4 02-10-2003 09:34 AM
