Old 09-08-2012, 09:02 AM   #1
dznf0g's Avatar
Oswego , Illinois
I finally got the courage.....
....to tackle this....
You may remember this from 2 years ago. The PO did something which I have never been able to figure out, but the rib that the corner protector hinge is attached to was caved inward and the panel was oil canned.
After pondering it for two years, I peeled back the mouse fur behind the couch and went after the rib, without removing the inner skin, with a block of oak and a 5 lb sledge.
I didn't take any pictures of this process...too nerve wracking, but slowly I began to see the rib straighten out from the outside.
Then I got out all my body stuff...
I then worked with the pneumatic suction puller, hot glue puller, and various high point relief tools.
I wound up with this:
As usual with aluminum skin repairs, with no access to the back of the outer skin, it's not perfect, but a lot better.
-Rich-
Old 09-08-2012, 09:15 AM   #2
1971 21' Globetrotter
Cave Creek , Arizona
Finally got the courage...
That looks great!
Nice job, man!
If I ever hit anything, I'm gonna look you up!
"Money frees you from doing things you dislike. Since I dislike doing nearly everything, money is handy." Groucho Marx
snakecharmer is offline   Reply With Quote
Old 09-08-2012, 09:18 AM   #3
dznf0g's Avatar
Oswego , Illinois
Thanks! I'm getting better at it each time I get after a dent, but I'd really rather experiment on other trailers!
I still have to discipline myself that "less is more", especially with the hot glue puller. It's really hard to see what you are accomplishing until you remove the tab from the skin. I keep creating high spots.
-Rich-
