Old 08-28-2007, 07:01 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
how would you fix this?
I removed the CB bracket that the PO installed. Underneath were these holes (must have missed the first time). I planned on putting in Olympic Rivets in the holes, but these are so close together that I think they'll overlap one another. How would this repair be done properly? Maybe fill one hole w/Vulkem & put the rivet in the other? Expert advise needed! Thanks in advance.
Name:	holes from cb bracket 1.gif
ID:	43993   Click image for larger version
Name:	holes from cb bracket 2.gif
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-28-2007, 07:08 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
In the past, I've needed to fill a few holes in my TradeWind similar to what you're describing here and one was along a rib. One of the three collapsing legs on the stem of the Olympic would have been in the way. I cut off one of these before installing and it went in just fine. In your instance, I would install the top ones as the full Olympics and remove one of the legs on the bottom row of holes.
Good luck and be sure to use plenty of Vulkem.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-28-2007, 07:09 AM   #3
Those holes are to large for olympic rivets.
You could seal the holes with vulkem, and cover those two areas with a small metal plates, using olympic rivets.
Old 08-28-2007, 07:21 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
Actually, Andy, I just ran outside w/an Olympic Rivet & the holes are too small for them. I'd have to drill them larger to fit an Olympic Rivet in them.
Becky
1964 Bambi II
1988 Avion 32S
Old 08-28-2007, 07:35 AM   #5
1967 22' Safari
AMARILLO , Texas
olympic rivits
Andy, I'm new to A/S trailers (or any trailers). I have used the search function, but need information on olympic rivits and "rivit shavers". I've seen that tool mentioned, but no info on how to use it ar what it does. How does the top of the rivit stay round and polished?
10brink is offline   Reply With Quote
Old 08-28-2007, 07:51 AM   #6
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
from a painted airstream....
Does any ever use TIG for holes like that? A qualified welding shop would make quick work of filling the holes and the owner could carefully finish the work with a dremel tool? My friends who restore aluminum bodied cars use this process routinely.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 08-28-2007, 08:06 AM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Andy-
When you say metal plates, what are you refering to?
In my opinion, patching over the area with a sheet of aluminum would look really bad! While in the process of restoring our 1960 Trade Wind we have come across this problem in several areas and I think filling the holes with rivits always looks so much better. Patch jobs are for amatures!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 08-28-2007, 08:28 AM   #8
Becky B.'s Avatar
1964 17' Bambi II
Rick,
Did you take care of the problem like flyfshr did? I don't think I want to go the plate route either.
Becky
1964 Bambi II
1988 Avion 32S
Old 08-28-2007, 08:49 AM   #9
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
With out some sort of backing plate you will likely get cracking over time. The bracket was the backing plate.
Michelle TAC MT-0
Sarah, Snowball
Old 08-28-2007, 08:51 AM   #10
Rick,
Becky.
Sorry, from your photo it looked like the holes were too large.
Certainly, then, you can use olympic rivets.
Enlarge the holes witha #21 drill bit.
Add a little vulkem to the stem of the rivets, then insert it into the hole.
After you pull the rivet stem, some vulken should come out from under the rivet head.
That's a good thing.
Clean up the excess vulkem with a little gasolene or even rubbing alcohol.
Old 08-28-2007, 09:20 AM   #11
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Try searching using Rivet instead of Rivit...you should find the info you are looking for ~
Shari
Old 08-28-2007, 09:38 AM   #12
1967 22' Safari
AMARILLO , Texas
Shari, Sorry. Can't spell without spell check any more!
Old 08-28-2007, 10:35 AM   #13
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Depending on where the bracket was mounted, once the repair is complete is this an area where a decal, plaque, name tag or light would be appropriate if you don't like the appearance?
On one Airstream I looked at they had a name tag done up nicely by a trophy shop and they volunteered to replace it with one with our names on it if we bought the trailer. Turned out they'd punched a hole there and done a reasonable repair but it was always bothersome to them when ever they saw it. They did the name plate and it "worked" in that situation. We did not buy it but I did see it some time later and the new owners had put a light there instead and that worked even better. They paired it up with one on the opposite side so it did not look out of place.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Wish AND FIX UP list for MH PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 35 07-25-2009 09:49 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
