Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-22-2003, 05:07 PM   #1
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
How to replace sheet metal on exterior?
Note the little sheet metal panel on the front side of the step which is rusted through.. I think I can fabricate an aluminum panel to cover it, but 4 or 6 olympic rivets might make it stand out as a makeshift repair. What to do about the sheet metal step pull panel to make it blend in after the trailer is polished? Sand and paint it? With what? Diamond plate would look great but is that feasible? The finger pull is built into the panel.
TY in advance for any suggestions.
BTW, the lower area in front of the step is where I "bubba'd" some Southern Shine polish.
Rog
Rog0525 is offline   Reply With Quote
Old 10-06-2003, 05:52 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Roger, if that is a weld-seam, you can get a wheel grinder and grind it smooth, Then, you could use some (gasp!!) Bondo to fill in the rust hole, sand it smooth, and spray everything with steel wheels colored paint. It is semi-polished aluminum color, and should blend in well enough.
PS. would you like some cheese to go with that whine?
Old 10-06-2003, 06:21 PM   #3
Rog0525
Rog0525's Avatar
Images: 11
TY for your input argosy2o
I was actually thinking of going the bondo route but another Forum member has kindly volunteered to mig weld the hole, a much better solution which I plan to pursue.
I am constantly impressed with the generous nature of fellow Streamers. I am delighted to be part of this Airstrem 'family'.
Rog
Old 10-06-2003, 06:25 PM   #4
overlander63
Rivet Masher
L.A. , California
Roger, the Bondo thing is a second-best solution, I didn't mention the welder because not many homeowners have access to one, but everybody knows about Bondo...
Happy trailing.
Old 03-27-2004, 07:34 PM   #5
Rog0525
Rog0525's Avatar
Images: 11
Went the bondo route
Now that Spring is finally springing, I'm getting back to those things on my 'to do' list, one at a time. The sheet metal panel on the rear side of the step was also starting to rust.
The mig welding offer didn't bloom so I sanded the area, applied 3M body repair tape, bondoed it , primered it and painted with Krylon Aluminum. Repainted the step while I was down there.
Now on to the next project. which I think will be stripping and painting the tongue.
The fun never ends.
Rog
Name:	saturday photos 019.jpg
Old 03-27-2004, 07:44 PM   #6
biggerbadbrad
Profile:
Thumbs up Nice job Rog
Looks great!
bbb
biggerbadbrad is offline   Reply With Quote
Old 03-27-2004, 08:25 PM   #7
GT1963
LADYBUG
GT1963's Avatar
Profile:  1963 19' Globetrotter
2005 22' International CCD
Lakefield , ON
Images: 59
Hi Rog..
What happened to the SS polish job on the front bottom. By the posts it looks like about 18 months later - is that about how long the shine would last if you don't put some type of protector on after the polish.
Just curious as we will be attempting our polish this spring - have read a few long and tedious threads on "opinions". Seen the immediate results, but would like to see long term. I know all climates will be different as well as how each coach is protected from the elements too.
Great job on the foot step. Ours will need a good sanding and re-painting but in excellent condition - no dents and operates perfect - quite a neat little step
GT1963 is offline   Reply With Quote
Old 03-27-2004, 08:54 PM   #8
Rog0525
Rog0525's Avatar
Images: 11
GT, I just rubbed some SS on that area as a quick test. I did not strip the clearcoat before nor did I wax it afterward. Both of those things would have to be done for a long term shine. The time between before and after photos was just 6 months, btw. The trailer sat in a field all winter and has not had a spring bath
But thanks for mentioning the step. Gives me an excuse to post the other pic I snapped today.
I'm sure glad the steps were better constructed than the rock guards.
Rog
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 11:20 PM
Twin bed standard sheet? TomW General Interior Topics 5 03-09-2004 03:00 PM
Sheet metal Jim Miller Parts Archive 3 07-08-2003 12:16 PM
need to replace the wheel...are there jacking points? 60traveler Towing, Tow Vehicles & Hitches 1 06-25-2003 04:05 PM
Exterior Door Hinges LKappenman Doors & Locks 24 01-23-2003 09:49 PM
test
