Old 05-02-2010, 08:25 AM   #1
Santa Fe , New Mexico
How to remove bulkhead cabinet??
RE: 2006 Safari SE, Front Bedroom
I have a dent in the center rear exterior exterior panel that I believe can be pounded out from the inside. First though, I need to take down the bulkhead cabinet. I can't even begin to see how this could be done, especially considering all the audio/visual wires running to stereo on the left side as you face the cabinets from inside the trailer. There are no obvious bolts/screws to take out. Has any reader done this? Could you send me a private message with your phone number so I could talk to you? I'm open to that because it doesn't seem like anyone could have the patience to write down all the steps needed.
mistermcfrug is offline   Reply With Quote
Old 05-02-2010, 08:38 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
It's pretty easy to unhook the stereo through the access panel inside the curbside cabinet. Good lighting and a mirror is needed. Tag everything you unhook.
I recall Airhog1 (Gene) mentioning that the curbside & roadside face pieces were held on by finishing nails. Knowing that, I looked for and found the filler covering the holes once upon a...
When you're looking inside the stereo area, I wonder if the light and mirror setup could help you see any attachments to the wall back in that corner? I'd wager on above & below in that little space. Both ends.
5 meter Langford Nahanni
Old 05-02-2010, 08:53 AM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
we have a 2002 Six Sleeper for which we had a similar question.
I spoke with Dave Schumann at AS HQ who advised me that at the factory the "roof lockers" are first attached to the interior end caps on a bench by screwing through the back side of the cap and into the wood, and then the entire interior end cap assembly is riveted into place. so the fasteners you seek are inside the wall, not where you can reach them.
a little bit of "you can't get there from here." not the answer you were looking for, I'm sure.
though, I'll bet Andy or someone else smarter than me might have a less painful solution?
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-02-2010, 09:30 AM   #4
Originally Posted by jm2 View Post
... the "roof lockers" are first attached to the interior end caps on a bench by screwing through the back side of the cap and into the wood, and then the entire interior end cap assembly is riveted into place. so the fasteners you seek are inside the wall, not where you can reach them.
End sections are assembled vertically and all outer skin is in place before the end sections are moved onto the new Airstream's floor. The complete shell is assembled on that floor before ever being mated to a frame; it has only outer skin until many steps later. The water shower test is done. Wiring, insulation & inner skin are installed next. The shell is virtually complete when the new coach is moved to the other side of the factory where the cabinets are installed.
I'm in the dark how the hanging end cabinets could be installed by fastening from the outside. Sure hope we hear more.
Old 05-02-2010, 09:43 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
"pounding out" the dent
I hate the sound of that. Thin aluminum stretches to easily.
While I have not done this....I did see it done. Hot glue some (several) six inch long by 1/4 wood dowels to the exterior dented surface. Then pull on the dowels...spreading the pulls out....you will be able to get alot of the dent out that way without acessing from the inside. Then remove the glued dowel and clean the surface. Who knows...you might get real lucky if the dent is shallow and no interior bracing is involved. Good luck.
Old 05-02-2010, 10:05 AM   #6
And on top of it I'd hate to get into the panel jigsaw puzzle and all the rivet removal you'd be facing. Why not one of the suction devices? Search deeper on 'suction' than I did. For starters...
http://www.airforums.com/forums/f381...ink-52222.html
http://www.airforums.com/forums/f381...nts-61961.html
http://www.airforums.com/forums/f381...nel-36058.html
http://www.airforums.com/forums/f381...tml#post836322
Old 05-02-2010, 03:43 PM   #7
Thanks!
Thanks CanoeStream. I've been researching your ideas, particularly the "paintless dent removal" option. Tentatively, it appears that a talented dent man can do what I'd call a 98% repair, not absolutely perfect but extremely close. That will be fine for me. I'm starting to take a look at Dent Force, a Nashville, TN company whose owner travels around. We'll see. I am deeply appreciative for CanoeStream's comments as well as the other comments.
Old 05-02-2010, 04:15 PM   #8
Hmmm, back to square one. The Dent Force guy said he couldn't do anything. I'd like to put up a photo of the damage but I can't figure out how this site even works. I don't see how you add a picture to a post.
Old 05-02-2010, 04:27 PM   #9
To add a photo, downsize a jpeg to no more than 1600 x 1600 pixels max.
ref: http://www.airforums.com/forums/f138...tml#post612569
Old 05-02-2010, 05:40 PM   #10
Body damage
These are the dents I'm trying to figure out how to pull out, push out or somehow repair. It looks like taking out the bulkhead cabinets is "impossible", so pushing the dents out is tough. But at the moment, I can't see how to pull the dents out. The paintless dent removal sites I find all talk about having access to both sides of the metal.
ID:	101684   Click image for larger version
How do you make a bulkhead? Safari Tim General Interior Topics 24 01-30-2007 12:01 PM
Attaching bulkhead guy99 General Interior Topics 18 12-11-2006 04:34 PM
inner over bulkhead twoguys General Interior Topics 5 11-03-2005 05:40 AM
Interior Bulkhead RichardM General Interior Topics 0 08-14-2005 11:10 AM
Bulkhead Structural Value 69Ambassador General Interior Topics 24 03-21-2004 07:43 AM
