Old 05-03-2009, 08:46 AM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
How to fix hole in skin?
Was drilling through a stud to pull a wire to repair outdoor light and drill bit must have slipped and pit a small hole through the outside skin. It happens to be directly behind the awning track making it not noticable when awning is up but visible when awning is down. Any thoughts on how to repair? It's about a 1/4" and not totally circular.
RichHog is offline   Reply With Quote
Old 05-03-2009, 08:48 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you can get in there you could put a rivet in the hole, or just use some sealant.
Good luck.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 05-03-2009, 08:53 AM   #3
Fill it with Vulkem, carefully.
It then would look like a patch, for a previous awning.
But then again, small patches on a almost 40 year old Airstream, become routine.
Old 05-03-2009, 09:00 AM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
1/4 " huh,
I'ld break off a arrow shaft and stick it in the hole leaving the feathers and notch exposed on the outside of the trailer.
Then you could make up lotsa stories about your travels.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 05-03-2009, 09:53 AM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Originally Posted by doorgunner View Post
1/4 " huh,
Don't ya luv doorgunner's sense of humor? But I know Tim 'just' enough to know that he's serious! He'd do it.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-03-2009, 09:57 AM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Neil.
I kind of like the idea.....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-03-2009, 10:55 AM   #7
2005 19' Safari
GLENDALE , AZ
Hardware stores (like ACE) carry rubber stoppers and plugs in various sizes back in the drawers that contain odd screws, fasteners, etc. Not sure what the hole looks like now; but if a black plug wouldn't look too bad cosmetically (your call), enlarging the hole a little to an appropriate size for the plug (and to make it round) and sealing it before installation, could be an easy weather-resistant repair.
Old 05-03-2009, 11:25 AM   #8
lynn's Avatar
Olympic rivets come with different size heads.Airstream uses the larger size rivet around the opening on slide out trailers.The head should cover the hole you described.
lynn is offline   Reply With Quote
Old 05-03-2009, 12:25 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
Neil, Tim will be full of all sorts of ideas if we show him this next thread - http://www.airforums.com/forums/f381...html#post58886. A new service at rallies to go along with Nuvite demos, Sealtech testing, swap meet -- and now custom 'distressing' of our silvertwinkies. I like it!
Sad thing is he will charge for the service...
5 meter Langford Nahanni
Old 05-03-2009, 09:29 PM   #10
FreshAir's Avatar
1966 24' Tradewind
Bob, I've attended several rallys that Tim was present also. He is very generous with his time and doesn't hesitate when asked for help or guidance. He comes off as a tuff marine..uh, oh.. he'll pound me some for not capitilizing Marine. I'll make up for that with MARINE. Anyway he is tuff but do you know that he takes his kitten everywhere with him...even in his kayak!
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 05-03-2009, 09:41 PM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I almost hate to admit it but...
I am fighting off the temptation to put a plate with arrows sticking out of the back of the Trade Wind. Genius.
Rodney
and the
My Blog
Old 05-03-2009, 09:44 PM   #12
Neil.
Oh yes, I am more than familiar with Tim. Even to the point of a thread devoted entirely to thanking him for going beyong the max in helping fellow forum members. My post was in his spirit of playfulness between times that we lay it on the line for others.
Now... Anybody ever stuff an insufferable garden gnome in an Airstream gash?
Old 06-25-2009, 04:09 AM   #13
NY_Chairs's Avatar
1971 31' Sovereign
Arcade , New York
How about a moose head, or butt?
I just removed the little FO indicator doohickey since it was now useless. The screw holes can be riveted, but the larger oval hole that the wires pass through needs a little bit more. The arrow idea would be perfect...
Rich
1971 31' Sovereign
1988 Chevrolet School Bus (Converted)
NY_Chairs is offline   Reply With Quote
Old 06-25-2009, 06:24 AM   #14
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Cut up your favorite canned beverage can,... use vulkem and rivits ( just kidding) Same Idea with a patch of new skin material or make hole bigger and add exterior outlet? Mike
memgrove2000 is offline   Reply With Quote
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Hole in the SKIN - How to fix clancy_boy Ribs, Skins & Rivets 13 06-13-2006 08:21 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Drill a hole Chuck Ribs, Skins & Rivets 17 05-31-2005 04:26 PM
We've got a hole - now what? Janet H General Interior Topics 10 07-05-2004 11:47 PM
