Old 08-17-2019, 09:00 PM   #1
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
How Rigid Should the Shell Be
Hello everyone, thanks for stopping by.
I'm a complete airstream newb and have thrown myself into the deep end of airstream restoration. And boy is there a learning curve.
So, my question for all those more knowledgeable. How rigid shoild the outer shell be. If you walk around the trailer, should you be able to press into the shell, watch it bend in and then come back out?
I am still trying to understand the concept of how rhe shell attaches to the frame via the subfloor so that it all has strength. But still...
How flexible should the shell be???
I have a 1972 29' Ambassafor that i have started to strip down. It has a few dents around the back which is fine with me. I will try and push them out once the inner skins are removed.
But does the whole trailer lose strength because of this???Click image for larger version
ID:	349722Click image for larger version
Swrider is offline   Reply With Quote
Which Brackets for Renogy Rigid 100w panels? thiel Generators & Solar Power 7 03-25-2018 10:01 AM
Rigid foam board insulation in belly..XPS or EPS? Jeremy9107 Repairing/Replacing Floor &/or Frame 4 02-19-2018 10:57 PM
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 10:13 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Why gas connections rigid copper? Splitrock LP Gas, Piping, Tanks & Regulators 15 09-29-2010 01:22 PM
