Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 11-13-2018, 02:07 PM   #1
2005 19' International CCD
Phoenix , Arizona
How much does it cost?
To have Airstream dealer replace a lower panel on a 25 ft. 2018 curb side panel? This would be for labor and part.....Does $1,200 sound right? Is this TOO LITTLE? Thanks.
DAHBABY is offline   Reply With Quote
Old 11-13-2018, 02:16 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If it's the panel in between the end caps then $1,200 may cover the cost for just the panel; let alone the labour to install it. It would suprise the heck out of me if there were a panel on any Airstream you could replace for $1,200.
I'm thinking you're way off base; be prepared to be shocked.
Cheers
Sidekick Tony
Isuzusweet is offline   Reply With Quote
Old 11-13-2018, 02:18 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Is this a flat sheet, or one of the formed "corner" end-cap pieces? Anyway, for a formed piece, it sounds about right. The rule of thumb used to be to expect to pay about $1000 per segment to have that work done, and prices are only going up.
good luck!
Old 11-13-2018, 02:20 PM   #4
A W Warn's Avatar
2000 25' Safari
$1200 is close to the cost of the material. Call up a dealer and ask. Or take photos and send to Airstream to get an estimate.
If you replace the rivets with buck rivets (as original) the interior has to be removed. (more expensive)
If you replace the rivet with Olympic rivets the work can be done from the outside, but the repair will be noticeable by anyone who knows the difference. (less expensive)
Alan
Old 11-13-2018, 02:26 PM   #5
Phoenix , Arizona
Thanks. The dealer has told me that their costs to replace the straight panel for labor and the part is $1,200. That seems low to me.
Old 11-13-2018, 02:55 PM   #6
Belegedhel's Avatar
Houston , Texas
If it is a flat sheet, then the cost of the material is probably less than $100 (depending on whether they source it locally, or buy it from Airstream with the factory clear coat). The typical way shops do these repairs is from the outside using Olympic rivets. If they know what they are doing and don't do something goofy like doubling/overlaying the panel, the only way you will know that it has been replaced is by examining the shaved heads of the rivets.
So, questions to ask:
-Will the replacement panel be doubled or overlayed?
-Will Olympic rivets be used, and the panel replaced from the outside?
-Will the replacement be Airstream quality plasti-coated aluminum, or bare sheet sourced locally?
There are ways to do this repair that can keep the cost low (ie., $1200), you just need to understand the compromises being made.
good luck!
Old 11-13-2018, 06:10 PM   #7
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
It's way too little estimate ... I speak from experience.
Frank&Mike is offline   Reply With Quote
Old 11-13-2018, 09:53 PM   #8
Phoenix , Arizona
Thanks to all who responded so far![emoji4]
Old 11-14-2018, 10:08 AM   #9
1994 34' Limited
colebrook , Connecticut
belting and trim
Does the quote include any belting or trim? I can tell you the Airstream service center will use Olympic rivets. Although on a panel replacement I had done they used regular pop rivets also. I have not found any bucked rivets used in segments on my 94 classic.
Mark
malett is offline   Reply With Quote
Old 11-14-2018, 12:01 PM   #10
2014 25' Flying Cloud
Temple , Texas
The front curb side, in front of the wheels ( curved bottom one) is around $2,000. I did one last spring at an Airstream dealer.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 11-14-2018, 01:14 PM   #11
Wichita Falls , TX
Doesn't your warranty cover the cost?
ga adkins is offline   Reply With Quote
Old 11-14-2018, 02:27 PM   #12
1975 27' Overlander
Galena , Illinois
I've replaced 5 panels. Panel price from Airstream is $550 each and $1,300 each one to have installed. Insurance paid so I didn't care but those are 2017 numbers from an Airstream dealership.
75Bob is offline   Reply With Quote
Old 11-14-2018, 09:17 PM   #13
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
A recent estimate from the mothership was: Metal: $ 8.91 per sq. ft. and Labor $88.88 per sq. ft. Sounds like a great do it yourself job.
guskmg
guskmg is offline   Reply With Quote
Old 11-15-2018, 10:38 AM   #14
Phoenix , Arizona
Thank you to all that have responded!
Old 11-21-2018, 09:47 AM   #15
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Not from experience, but from reading, panel replacement cost wise, that does seem low. Remember the saying, "you get what you pay for"
I would send picture to other dealers just to see what the ball park is.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 11-21-2018, 11:27 AM   #16
toastie's Avatar
1955 22' Safari
Great Lake State , .
Sounds about right, just a couple hours of work.....
toastie is offline   Reply With Quote
Old 11-21-2018, 11:28 AM   #17
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
I just paid 1820 for my lower front curb side corner panel and trim. Does not include any polishing.
'61 Safari
https://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 11-21-2018, 04:08 PM   #18
2018 27' Tommy Bahama
Wilton Manors , Florida
Too little maybe
I buggered up about 2’ of the left side of our new 27’ on a gas station protective pole after 2 hours of ownership. Scratched up a 2’ square area and damaged the lower molding. Asked for an estimate from the Airstream dealership where we bought it and was given a rough estimate of 10K. He explained that the whole panel has to be replaced. Damaged one removed by hand drilling out each rivet, then new blank sheet is laid out with damaged one over it as a template, with each feature hand cut out, then re-riveted, etc. I decided to wait and make sure I wasn’t going to inflict more damage learning how to pull and park, etc.
Hvcooper is offline   Reply With Quote
Old 11-21-2018, 11:01 PM   #19
2006 31' Classic
DuBois , Pennsylvania
Just returned from dropping off our 31' AS at Jackson Center. Thanks to a hail event, they are replacing the rear 5 panels above the beltline. R&R with Olympics is 10K. The factory labor rate is 120-ish if I remember correctly.
To use the factory rivets(remove & replace interior) the cost would be double.
If the olympics aren't shaved properly, your eye will pick out the repair. I would want to see some of their work before I said OK.
Streamin is offline   Reply With Quote
Old 11-22-2018, 12:29 PM   #20
1975 27' Overlander
Galena , Illinois
Are you serious? A couple of hours? Airstream quoted me 10 hours per panel at $125 per hour. I found a guy at Camping World that used to work for Argosy that knew how to install panels. They charged me $850 per panel for labor only. The repairman told me I stole it from CW cause it took him more than 8 hours to replace one. I had them replace 5.
How much do you think it would cost to repair bellypan? bnhilfiger 1960 - 1965 Safari 5 03-20-2008 07:44 PM
How much would a restoration cost? Brian W Dollars & Cents 33 09-27-2006 05:37 PM
How much did old Airstreams cost when new? Andrew M. Franklin Trailer Values 9 09-22-2004 12:45 AM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 05:20 AM
