Old 07-30-2015, 12:10 PM   #1
Westminster , Colorado
How many pop rivets?
Certainly this has been covered before, but is there a way to figure out how many pop rivets are needed to put the interior skins back together? My AS is 26 feet. I know they are cheap, but I don't want to under or over buy.
Thanks!
painterfam is offline   Reply With Quote
Old 07-30-2015, 12:26 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Counting comes to mind....I guess you could measure the number of rivets in a foot, measure the seams and do the math.
CRH is offline   Reply With Quote
Old 07-30-2015, 01:08 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You can get the proper size and composition of pop rivets at your local big box store--just make sure they have aluminum mandrels. You might try buying a hundred, and then get them in smaller boxes of 25 or 50 as you see how fast you are consuming them.
Old 07-30-2015, 01:19 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Beware that most big box stores (as well as most local hardware stores) do not sell pop rivets with aluminum mandrels. The mandrels in most of these commonly available aluminum pop rivets are usually steel. I've found aluminum mandrel pop rivets at Vintage Trailer Supply.
Bob Martel
WBCCI# 5766
Old 07-30-2015, 03:33 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Ace hardware carries aluminum rivets with aluminum mandrels. Seems to me we went through over 300 rivets to put all the interior skins back into Little Girl. I know I kept buying boxes of 100 each time, but I never really counted how many boxes we went through. Fortunately, they are not all that expensive. And if you buy too many boxes, Ace will take unopened boxes back. I bet VTS would too, which is another source I use often.
Chris
Old 07-30-2015, 05:11 PM   #6
Chelsea , Michigan
Images: 12
Good to know about ACE!
Bob Martel
WBCCI# 5766
Old 07-30-2015, 05:14 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Fastenall is also a great source for the good rivets.
Old 07-30-2015, 05:42 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, I got my last batch from Fastenall. How many you need? Count them. Buy more than you need for this one job. You will use them eventually. I used a dozen today. Glad I had them, not really worth the drive to buy that few.
MICHAEL
Old 07-30-2015, 07:18 PM   #9
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
My 17 footer took 1000. I know this because I bought bulk rivets online (an eBay store, I think) in several sizes. The bag of 1000 was 1/8" x 1/4" and bought specifically to re-install the interior skins. I used them all...
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-31-2015, 09:24 AM   #10
Belegedhel's Avatar
Houston , Texas
I've bought aluminum mandrel rivets from Lowes, Home Depot, Ace, Do-It_Rite, Granger, etc. You just have to be careful that you are getting what you think you are.
Old 07-31-2015, 09:41 AM   #11
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Go to Harbor freight and buy one of their pneumatic rivet guns. Speeds the process tremendously and saves your hands from squeezing the pop rivet tool a thousand times.
3/16" Air Hydraulic Riveter
You will be glad you have it, I promise.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-31-2015, 09:54 AM   #12
1972 27' Overlander
Woodburn , Oregon
Yes this is a must when doing large amounts of rivets , I think this tool cinches up the rivet tighter than doing it by hand , I couldn't be without mine
shineybullet is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
Closed End Pop Rivets vhord Ribs, Skins & Rivets 18 05-29-2010 10:04 PM
Pop Rivets For Bumper tgh97531 Ribs, Skins & Rivets 2 01-22-2010 06:59 AM
