Old 11-18-2007, 10:34 PM   #1
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
Rivet How to heal a NASTY SCRATCH?
I just bought this 2004 25' International. It came with the nasty scratch.
How do I fix it?
Will letting it remain as is through the winter possibly cause a crisis?
Forum searches seemed to shed any solutions.
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 11-18-2007, 11:07 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I hope you get a good answer to this question as my "new" 76 Sovereign has this same scratch.
juel is offline   Reply With Quote
Old 11-18-2007, 11:29 PM   #3
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
IF it has gone through the clear coat you are going to need to fix it soon!
Otherwise corrosion will develop under the coating. To remove a deep scratch in the coasting is like repainting a damaged wall. You have to smooth and feather the edges with sanding and re-apply the coating by spraying it on.
If it is just a surface scratch then hand buffing the area with finer and finer abrasive will do the trick.
Michelle TAC MT-0
Sarah, Snowball
Old 11-19-2007, 05:38 AM   #4
How do I fix it?
If the scratch is into the metal, then the only fix is replacement.
Insurance companies will cover that type damage.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-19-2007, 05:48 AM   #5
Images: 59
I wish I knew the answer. I would take it to an Airstream dealer for a quote.
Your insurance company won't cover it. They will probably drop you if you ask them.
Old 11-19-2007, 05:59 AM   #6
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
pimp your ride
you could pimp your ride
or go with something more appropriate to cover the scratch and protect the metal beneath
elbundi is offline   Reply With Quote
Old 11-19-2007, 07:08 AM   #7
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Scratch and Burn
That is a great idea
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-19-2007, 09:54 AM   #8
_
hi sound-silver...
ouch!
the definative cure is panel replacement. side panels are the easiest to do...
but still expensive, and way more than most insurance deductables...
for very superficial scratches, megs scratch X will do wonders, followed by a poly sealant wax.
IF the scratch is down to bare metal (does a finger nail catch in it?) it does need to be covered....
start with meg' scratch x or a very light 3m compound (1200)s or finishing polish.
Meguiars SCRATCH X
3M Perfect- It Rubbing Compound restores mild to moderate paint imperfections so that your vehicle looks like new.
clean parallel to (lengthwise) the grove and then exactly perpendicular, avoid a circular pattern.
once it's cleaned you will need to decide HOW MUCH of the grove edge to remove...
buffing just a small amount is the safest approach, but the scratch will be more visible.
taking enough material off to get it smooth, will remove MORE protective clearcoat in the surrounding area (not good)
3m sells a 'scratch repair kit' that includes small amounts of several grades of compound.
this site also has high quality polishes and compounds...
Compounds, Polishes & Glazes
i like the menzerna's and 3m and meguiars products.
and here is a chart comparing the polishes/compounds...
Compound Polish Glaze Comparison Chart
and a simple 'how to' on scratch removal...
How can I remove paint scratches?
after completing the 'removal' stage, some protective coating must be applied...
poly sealant waxes or waxes with 'fillers' will work temporarily and must be reapplied 1-3 times yearly.
clear coat touch up paint, or clear nail polish can be applied directly into the blemish, and lasts longer..
a/s also sells a clear 'acrylic touch up' in a spray can for 10-12$ which may last longer too....
IF you reapply any of these clearcoatings, do it in very thin layers with plenty of drying time between coatings...
mask off the surrounding skin and apply as narrowly as possible to the specific defect area.
when finished, the surface may be raised and more annoying than the original gouge,
if that is the case, consider polishing the clear coat patch, again with the lightest compound (1200 or 2000 or 3000)
best of luck, and the decals aren't a bad idea either!
cheers
2air'
the info above appies to the newer ALCOA clearcoated aluminum panels, NOT the plasticoat applied by a/s up till '99 or so....
Old 11-19-2007, 11:59 AM   #9
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I like the flames. I doubt if I want to try to fix the scratch on my 76. I'm just going with "it adds character" approach. May put something on it for protection, like some kind of sealer with an artist's brush.
Old 11-19-2007, 12:29 PM   #10
1978 29' Ambassador
Moab , Utah
I awoke this morn to much helpful info from you all. Many thanks...
After a hearty cup of mudd I decided to inspect closer and see what I'm up against. As is most always the case, the owner wants to see the potential problem in the kindest way. My optimism vanished before the caffeine buzz could kick in and I was about to submit an order to ELBUNDI for the Airstream Flame Sticker Kit It seems the gouge borders on kind of nasty. When I run a fingernail down it there is a slight catching, but not a definitive groove for it to snag on.
2airishuman, I have extend bonus gratitude to you. You broke it down to where even a noob like me now has an attack plan or three. I have nothing to lose if the skin looks imperfect or if I bungle the entire job.
Here's some more pics.
Old 11-19-2007, 09:35 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Cover Up
Hi, can you tell where my boo boo is/was?
Name:	Airstream Mods 063 (Small).jpg
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 11-19-2007, 09:46 PM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I've done very little repair work, but I just covered a shallow scratch with clearcoat. I masked the side of the airstream with blue painters tape, then spraying lightly - several coats. It isn't perfect, but I'm probably more likely to see it than a casual observer.
Paula
Old 11-20-2007, 10:18 AM   #13
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Oh, say can you see?
Nifty idea.
Pat
pmclemore is offline   Reply With Quote
really yellow, nasty vinylclad aluminum walls. Venpetra Member Introductions 6 09-10-2007 11:57 AM
starting from scratch~moho vs. trailer? ~flutterbee~ Buyer Guidelines 14 07-14-2006 08:48 PM
Rewiring - starting from scratch 59er Electrical - Systems, Generators, Batteries & Solar 32 10-26-2005 04:20 PM
Clearcoat scratch removal mcostanzo Clearcoat, Exterior Paint & Trim 3 07-01-2003 09:28 PM
Nasty sharp corner Pahaska 2002 - 2005 International 0 11-10-2002 04:52 PM
