Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-04-2013, 10:11 PM   #1
mapleton , Utah
How do I clean Vulkem from Clecos?
I've been doing a lot of riveting lately, reframing and reinforcing the roof for A/C among other things and I now have a bunch of clecos that I forgot to clean while the vulkem was still uncured. Anybody have any easy tricks for me? I'd really rather not use MEK if I can help it- that is nasty stuff.
thanks, tim
rumrunner is offline   Reply With Quote
Old 08-05-2013, 04:08 AM   #2
Baltimore , Maryland
While wet, WD40. Once dry, elbow grease. MEK helps the elbow grease become more effective.
Old 08-05-2013, 04:42 AM   #3
Retired.
. , At Large
Mineral spirits or cosmoline remover.
Old 08-05-2013, 06:47 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We've used carb cleaner with good results.
Chris
Old 08-05-2013, 06:54 AM   #5
mapleton , Utah
thanks for the ideas. Looks like a good solvent soak and some hands on is in the cards.
tim
Old 08-05-2013, 07:50 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
My clecos generally have sealant on them, I have a small thin wire brush on a small bench grinder that I clean them up with. Gotta hold one to them pretty good as it will fling them hard against the wall if they get away from you. Maybe not the safest method but it works for me. I always wear safety glasses and heavy leather gloves doing this.
After an aircraft skin is changed we might have 500 plus to clean up.
