Old 11-05-2003, 02:36 PM   #29
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I took one of my belly pan segments to a metal supply house and they identified it as .032, and the closest new material we could find in their warehouse was a 4x12 sheet of 5052 aluminum. It lookes fantastic, has the tiny brush lines in it, and should more than suffice for the belly pan.
I like it so well, I am going to use some of it to spruce up the interior.
Anyways, it was $47.00 tax incl. for a 4ftx12ft sheet. The material is more than sufficient for my belly pan sections. I would not see much sense in using aircraft rated aluminum for cutting up into belly pan segments.
Uwe
www.area63productions.com
Old 11-05-2003, 02:48 PM   #30
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Uwe,
Could your belly pan have been replaced? My service manual on my 75 says the belly pan is .024 but then again they may have lightened it up by the mid 70's I by a lot of sheet goods from Phoenix Metals, the branch I use is out of Charlotte, NC. If you can get in good with your local architectural metals shop, they should know where the good deals are. We pay about $65 for a 4'x10' sheet of .063 the 5000 series stuff. Haven't checked on the good stuff yet.
Here is the link for Phoenix Metals http://www.phoenixmetals.net/
They are primarily out of the Southeast.
Aaron
Old 11-05-2003, 03:04 PM   #31
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Aaron,
It is possible that there are different materials found under my trailer, but if so, then it would have happened early in the trailers career. The reason i went for new material was that the old stuff is just plain gross and has been cut and riveted one too many times. Also, there were holes I no longer need since i rerouted the grey water line from the shower to accomodate my BAL jacks.
At $ 44.66 for a sheet, I guess I got a good deal. Airparts lists the same material for $ 6.50 per foot. ( 5052H32)
Uwe
Old 11-05-2003, 03:24 PM   #32
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Holy Moly is Right!
Hi Gang,
I have built experimental aircraft with AL and organic products (wood) and spent 20 years in the US Navy as a pilot and Aircraft Maintenance Officer. AL is my life!!!
Below is a link to an aircraft supplier's page on what the many types of AL are used for and their numerical nomenclature. From there you can look at their catalog for comparison pricing.
http://www.wicksaircraft.com/gotopage.php?page=59
Pages 68 and 69 have the sheet AL pricing with strength and usage information.
BTW if the local supplier is10-15% higher he might be the right person to purchase from anyway, as you may need something on short notice, and if he is still in business, you'll have a local source. You might even have someone to assist you when the bending, forming, etc. operations become more than you can handle without the brake, English wheel, misc tools so necessary in sheet metal work.
Before the flames start, I do not purchase all my stuff from the local supplier, mail order can and has saved me many dollars, but I do use a guide of 20%. If mail order w/shipping saves me 20% or more that's the way I generally go. That said, I have also spent more than mail order locally because of the additional service I received from the local merchant. (8' sheet brake to bend .125" for spars for example)
I hope this is of some benefit.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 11-05-2003, 05:22 PM   #33
Images: 59
Holy Moly
Great source! Beaucoup karma to you. Notice they also have lots of rivets and rivetting tools, and adhesives, and tons of stuff. Thanks.
Old 11-05-2003, 08:12 PM   #34
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
I agree - great site for info. Karma coming !
Page 51 has some polishes that are interesting.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 11-05-2003, 08:26 PM   #35
Firecop's Avatar
1978 31' Excella 500
Woodland , Utah
Just came on and read all the threads. Thanks alot. The wealth of info from this site is great. I am attempting to restore a '78 Excella 31' International to original factory condition, and this will help greatly. A special thanks to our A-6 veteran, Dinoburb, on the web source.
Firecop
Firecop is offline   Reply With Quote
Old 11-05-2003, 08:30 PM   #36
Creampuff
Creampuff's Avatar
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
Thumbs up WELCOME ABOARD FIRECOP
You will find a wealth of archived info in the restoration forums. Use the search engine on any topic.
Murray
AIR #189
