Old 01-30-2010, 11:24 AM   #15
Olielulu's Avatar
1972 25' Tradewind
Webb Lake , Wisconsin
I pulled all my panels and rolled them up inside the trailer, and duct taped them. the rolls were small enough for one person to move them in and out of the door. no snaking through the door and possibly causing more damage.
Olielulu is offline   Reply With Quote
Old 01-30-2010, 04:53 PM   #16
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks So much Sounds much safer and easier to store.
bwaysteve is offline   Reply With Quote
Old 01-30-2010, 05:00 PM   #17
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
holes and screws
Here are some hole pics and that nasty Alumaloy repair.
ID:	95069   Click image for larger version
ID:	95071   Click image for larger version
ID:	95073   Click image for larger version
Old 01-30-2010, 07:33 PM   #18
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by VIKING View Post
If you want to try your hand at bucking rivets you could get yourself some flush rivets to fill those holes. They have a head shaped like a phillips flathead screw, and they fit flush after you countersink the edges of the holes. I think they are standard on most aircraft now, to cut wind resistance down to the minimum. They can be pretty invisible when done well.
Good luck!
Rich the Viking
You will need 0.032 or 0.040 aluminum at least to countersink Rivets or Screws.
Michelle TAC MT-0
Sarah, Snowball
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Get rid of those holes-skin replacement markdoane Ribs, Skins & Rivets 6 09-28-2004 06:43 PM
Screw holes in my skin 58BUBBLE Ribs, Skins & Rivets 11 09-12-2004 09:53 PM
holes in the skin bhsl8 Ribs, Skins & Rivets 7 01-06-2004 05:52 PM
