Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-18-2009, 09:46 AM   #21
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
utee you beat me to it! What is that?
SilverHoot is offline   Reply With Quote
Old 03-18-2009, 10:07 AM   #22
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
I think it's called a hand brake as opposed to a full sized aluminum brake
They are both used for bending aluminum or sheet metal. One on a small scale, the other on a larger scale.
Which leads to my next question...If it bends metal, why do they call it a "brake"???
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-18-2009, 11:12 AM   #23
I thought bending metal was what happens when you forget to brake.
VIKING is offline   Reply With Quote
Old 04-14-2009, 05:38 AM   #24
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Marcus, a couple of months ago I went scrounging at a salvage yard in north Florida and came home with one of the extruded lids you first mentioned that I thought I'd use on my 63 Tradewind restoration. The original has cleaned and straightened up better that I thought it would and I'm going to keep it. If you are still interested let me know and I'll try to post a picture of the extruded one. I think I paid $10 for it.
dieseleagle is offline   Reply With Quote
Old 04-14-2009, 06:05 AM   #25
de,
Sure, would like to see a picture, thanks. Also, welcome to the Forums!
Old 04-14-2009, 08:23 AM   #26
Perfect timing for this thread! In my GTs past, someone cut the trunk down the middle and removed half of it. I recently went to a local scrap yard, Alan Steel in Redwood City, and bought a flat piece of 0.90" thick aluminum to fabricate my trunk cover. The advantage of buying the material there was that they would cut it to size - for a price of course. My total cash outlay for the material plus one cut was $25... They didn't have have cool extruded pieces, so my plan is to attempt a brushed finish using a sanding block and fine grit paper. I figure doing that and giving it a clear coat should do the trick. I opted for the thicker material to make up for a lack of nice bent stiffening features. Hopefully I can to attack the project this week, so I'll be sure to post some pictures.
One question I have is regarding the hinge rivets. It looks like the rivets that affix the hinges to the cover are solid bucked rivets. Are most trunk hinges out there pop riveted or buck riveted?
toddster is offline   Reply With Quote
Old 04-14-2009, 08:56 AM   #27
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
this may work
Marcus,
When they closed the Eagle Bus manufacturing plant in Brownsville a few years ago they sold out alot of bus siding aluminum. It was a wavy, extruded, polished, plate......about 3/8 thick. You can see it on most big busses...not plastic buses...on the road. I have see some of this material on Ebay...listed under ..of all things...aluminum. I have recently seen something similar listed in RV parts, being sold by high end motor coach manufactures.
Old 04-14-2009, 10:09 AM   #28
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Hope this works as I have not posted pics before.
If you want it I'll be happy to send it to you for $10 plus shipping.
Old 04-14-2009, 11:53 AM   #29
Thanks for the photos de, I'll check my dimensions and see if it's a match. I wonder how much shipping from FL to TX would be?
MR-- that's a good idea as well, thanks again to everyone for their input. For now I have riveted the old one back on, and it is serviceable, but not ideal.
Old 04-14-2009, 11:55 AM   #30
Mine is not the original bumper, though it's pretty much the same as original. I believe Terry said that my bumper came from an Argosy. For reference, my trunk lid is buck-riveted to the hinge, and the hinge is pop-riveted to the trailer, but that arrangement could be (and likely is) a result of the removal and replacement of the original bumper.
Old 04-14-2009, 12:30 PM   #31
Retired.
. , At Large
The bumper on your trailer now is from Balrgn's 1973 Argosy 26 he was parting out several years ago. The pop rivets are replacements for the pop rivets that were on the cover when we got the trailer. I did move the camloc mounts slightly to take advantage of somewhat better aluminum in the new locations.
As always, there are stories behind many "normal" things, and the bumper is one of them. Andre sold me the bumper, boxed it up, and sent it via UPS from his home in new Hampshire to our home in Florida. He got a bill from UPS after I had gotten the bumper, and installed it. The bill was for about $20 more than he charged me for the bumper and shipping combined. If nothing else, it is a study in shipping costs.
Old 04-14-2009, 12:46 PM   #32
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If you can find a shop that installs extruded aluminum running boards like these you may be able to buy a section from them. AZ Truck Accessories | Continental Accessories*4 Inch Back Series Extruded Aluminum Running Boards* I have used scraps from these places for all sorts of projects, including mounting an electric fuel pump.
Vaughan
Remove Bedroom Locker in 25' FB SE AZ-JH 2005 - 2010 Safari 3 08-12-2008 10:18 PM
roof locker latch help goransons Cabinets, Counter Tops & Furnishings 5 02-21-2008 01:19 PM
Opening the Lid to the tool locker??? farmboydkb Doors & Locks 9 02-28-2007 07:41 PM
paint can lid trick pinkflamingoes Lights - Interior & Exterior 1 02-13-2006 08:43 AM
Commodie Lid Question MileHigh General Interior Topics 7 03-10-2004 06:23 PM
