Old 03-17-2009, 08:19 PM   #15
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Yes, but when everyone's standing around helping you park, and the assembled crowd follows you around to the rear, you reach for that solid, gleaming cover, the crowd gasps.... priceless!
I bet Frank would.....
Marc
Old 03-17-2009, 08:43 PM   #16
1975 Argosy 26
1963 24' Tradewind
Ok, so 1/4" is too thick. How about this stuff with a small edge around it? And, would provide drying for the stuff in there... but also allow water in... hmmm.
Order Aluminum 3003 Perforated Sheet in Small Quantities at OnlineMetals.com
Or you could put it on top of the old one...
Marc
Old 03-18-2009, 07:07 AM   #17
VIKING's Avatar
Boulder Creek , California
I finally remembered to check mine for you. It has the original cover which is probably the same as yours, But it has been recovered with another sheet about the same thickness. The cover sheet wraps around the edges of the original so it has a thicker look to it, but it still bends easily and I wouldn't step up onto it until the day I plan on replacing it. I would think 1/8" thick would do very nicely if it's not unreasonable price-wise.
Rich
VIKING is offline   Reply With Quote
Old 03-18-2009, 09:01 AM   #18
Marc-- I do like the idea of making a spectacle out of the back of my trailer!
Rich-- I think adding another sheet is probably the quickest and most cost-effective answer. It would at least be slightly sturdier than the existing one.
I have enough 2024-T3 lying around to do it, but I think I'd have to take it to a fab shop with a long brake to get someone to roll the edge over. Probably still shouldn't cost me too much.
Thanks to all for the replies!
Old 03-18-2009, 09:37 AM   #19
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by utee94 View Post
...but I think I'd have to take it to a fab shop with a long brake to get someone to roll the edge over.
Just get yourself one of these. They are very useful when working on an Airstream.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-18-2009, 09:44 AM   #20
What the heck is that? Looks like some kind of terrifying, primitive dental tool!
Old 03-18-2009, 09:46 AM   #21
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
utee you beat me to it! What is that?
SilverHoot is offline   Reply With Quote
Old 03-18-2009, 10:07 AM   #22
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
I think it's called a hand brake as opposed to a full sized aluminum brake
They are both used for bending aluminum or sheet metal. One on a small scale, the other on a larger scale.
Which leads to my next question...If it bends metal, why do they call it a "brake"???
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-18-2009, 11:12 AM   #23
VIKING's Avatar
I thought bending metal was what happens when you forget to brake.
Old 04-14-2009, 05:38 AM   #24
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Marcus, a couple of months ago I went scrounging at a salvage yard in north Florida and came home with one of the extruded lids you first mentioned that I thought I'd use on my 63 Tradewind restoration. The original has cleaned and straightened up better that I thought it would and I'm going to keep it. If you are still interested let me know and I'll try to post a picture of the extruded one. I think I paid $10 for it.
dieseleagle is offline   Reply With Quote
Old 04-14-2009, 06:05 AM   #25
de,
Sure, would like to see a picture, thanks. Also, welcome to the Forums!
Old 04-14-2009, 08:23 AM   #26
toddster's Avatar
1967 20' Globetrotter
Campbell , California
Perfect timing for this thread! In my GTs past, someone cut the trunk down the middle and removed half of it. I recently went to a local scrap yard, Alan Steel in Redwood City, and bought a flat piece of 0.90" thick aluminum to fabricate my trunk cover. The advantage of buying the material there was that they would cut it to size - for a price of course. My total cash outlay for the material plus one cut was $25... They didn't have have cool extruded pieces, so my plan is to attempt a brushed finish using a sanding block and fine grit paper. I figure doing that and giving it a clear coat should do the trick. I opted for the thicker material to make up for a lack of nice bent stiffening features. Hopefully I can to attack the project this week, so I'll be sure to post some pictures.
One question I have is regarding the hinge rivets. It looks like the rivets that affix the hinges to the cover are solid bucked rivets. Are most trunk hinges out there pop riveted or buck riveted?
toddster is offline   Reply With Quote
Old 04-14-2009, 08:56 AM   #27
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
this may work
Marcus,
When they closed the Eagle Bus manufacturing plant in Brownsville a few years ago they sold out alot of bus siding aluminum. It was a wavy, extruded, polished, plate......about 3/8 thick. You can see it on most big busses...not plastic buses...on the road. I have see some of this material on Ebay...listed under ..of all things...aluminum. I have recently seen something similar listed in RV parts, being sold by high end motor coach manufactures.
Old 04-14-2009, 10:09 AM   #28
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Hope this works as I have not posted pics before.
If you want it I'll be happy to send it to you for $10 plus shipping.
Remove Bedroom Locker in 25' FB SE AZ-JH 2006 Safari SE 3 08-12-2008 10:18 PM
roof locker latch help goransons Cabinets, Counter Tops & Furnishings 5 02-21-2008 01:19 PM
Opening the Lid to the tool locker??? farmboydkb Doors & Locks 9 02-28-2007 07:41 PM
paint can lid trick pinkflamingoes Lights - Interior & Exterior 1 02-13-2006 08:43 AM
Commodie Lid Question MileHigh General Interior Topics 7 03-10-2004 06:23 PM
