Old 07-09-2014, 06:18 PM   #1
1969 27' Overlander
Middletown , California
help with dents,?
Hi Guys,
I have a 1969 27' Overlander with some dents. I live in Berkeley, Ca. but the trailer is in Middletown, Ca. near Napa Valley. I am trying to find a place to take it to have the dents removed, or perhaps have someone do it on site. I would also like the trailer polished so I'd like to know where I can go for that. Anyone in the San Francisco Bay Area that you might recommend?
Thank you!
Wade Skeels
Big Canyon is offline   Reply With Quote
Old 07-10-2014, 07:29 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Post some pictures of your dents, so we can give you more than rules of thumb. So, some dents can be pulled out using automotive "paintless dent removal" techniques. I have seen examples where it is very difficult to see where the dent used to be. Most dents won't simply "pop" out, and if they do, they tend to pop back in again. Any dent will result in stretching the aluminum, if only a bit. If the dent results in a crease, you will likely not be able to work the metal back into shape without at least removing the interior wall and insulation, and using some type of roller to work out the dent from the backside. It doesn't take a very dramatic dent to result in the need to replace the segment or panel, and this is typically the way to restore the appearance of the trailer to "like new." In the case of your '69, you can still buy the 2024 T3 Alclad aluminum that the flat panels are made of, but it is very unlikely that you will be able to buy a "new" formed segment (that makes up the rounded ends of the trailer) that will both fit and be made of an alloy like yours. So if it comes to a segment replacement, you have three choices: work the dent out as best you can, and tolerate some imperfection, find a used part made of the same alloy and use it as a replacement, or remove the segment, and find someone with and "English Wheel" who has the expertise to work the dent out without changing the overall shape of the segment.
newbie questions on 1970- any help for dents yipiia Roof 7 08-24-2010 05:43 AM
first big dents- help strayhorse Member Introductions 11 01-08-2006 05:03 PM
Dry ice and dents.... Silver Bullet Ribs, Skins & Rivets 19 11-13-2003 11:41 PM
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 10:11 AM
Dents Jenturnr Ribs, Skins & Rivets 1 03-11-2003 06:58 PM
