Old 06-09-2014, 09:17 PM   #1
Scouter Mike's Avatar
1970 23' Safari
Help! Small tear from a minor collision!
I had a minor collision with a post I failed to clear. The collision broke off the grab handle by the door and made a tear in the skin. Has anyone ever tried to weld and polish?
Name:	ImageUploadedByAirstream Forums1402370204.509846.jpg
Any repair advice would be appreciated!
Scouter Mike is offline   Reply With Quote
Old 06-09-2014, 09:47 PM   #2
Attachment 213945
You can add a patch plate over the tear.
You cannot weld the sheet metal.
Old 06-09-2014, 10:13 PM   #3
1970 23' Safari
Hi Andy, any chance you have a grab handle with a wider top that could cover the damage?
Mike
Old 06-10-2014, 08:19 AM   #4
Mike
I will check to see if I can find one.
Airstream does not have them though.
Old 06-10-2014, 07:28 PM   #5
1970 23' Safari
Thanks Andy. How about this part, do you have this drip channel?
Name:	ImageUploadedByAirstream Forums1402450099.109707.jpg
Old 06-11-2014, 07:42 AM   #6
3202 Ellie
boliversr's Avatar
1975 Argosy 24
milan , Michigan
You can weld it but proably need a pro to do it.
boliversr is offline   Reply With Quote
Old 06-11-2014, 11:52 AM   #7
Attachment 214009
Sorry, but no, we do not have that part.
Old 06-12-2014, 05:02 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I had a fellow TIG weld a tear on an older Excella. I used a Dremel to tidy the whole mess up. Turned out to be a blemish, but perfectly acceptable. If I had to do it over, a patch and rivets would work next time!
Old 06-12-2014, 07:41 AM   #9
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Patch, don't weld!
2024 Aluminum is NOT a weldable alloy.
A neatly done patch will blend into the background aluminum and you won't remember it's there in a few months, years, etc.
Old 06-12-2014, 08:14 AM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Look in the boat parts section of Ebay. There many nice assist handles and grips with larger bases available. They would easily cover your small rip and they install like any of those on an Airstream.
Old 06-12-2014, 03:44 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I have been thinking about this all day. I once saw a fellow with an oops like yours. He replaced the handle, to patch the tear, he commissioned an artist to make a patch with the families name somehow embossed and enameled. It looked really nice, personalized, and covered the tear without looking anything like a patch.
I should have taken a photo.... It was just that remarkable.
If I recall, he also added Excella blue LEDS to illuminate the lean handle.
Nifty
Old 06-12-2014, 03:45 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Argh should read Lexan handle.
Old 06-12-2014, 10:30 PM   #13
1970 23' Safari
Thanks for the advice. I did visit a very high end automotive restoration company today. These guys restore pretty much anything, and I don't think I've ever personally seen better workmanship.
They said its weld able, but might be a slightly different color.
I've got time to wait though, they said they couldn't look at it until August.
I'll look into the boat grips also.
small skin tear repair? rippie Ribs, Skins & Rivets 24 11-13-2013 10:26 AM
1986 Argosy Collision Damage squareboat All Squarestream Trailers 15 08-08-2010 03:49 PM
Need collision repair recommendation mistermcfrug Ribs, Skins & Rivets 3 04-02-2010 04:23 PM
Help ceiling tear Skyeyes2blue General Interior Topics 12 06-18-2007 10:10 AM
