Old 02-02-2009, 09:35 AM   #1
1969 21' Globetrotter
Cambridge , Massachusetts
Help newby to a productive afternoon - drill size?
Of first importance is that I find out how to remove the rivets that hold the inside skin and the belly pan so I can keep moving on my project. What size (and type) drill should I drill them out with? Are both belly pan and inside skins the same?
JoePfznik is offline   Reply With Quote
Old 02-02-2009, 09:41 AM   #2
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
our trailer uses 1/8" for the inside rivets and 3/16" on the belly pan rivets.
I assume you are talking about pop rivets as there are some Buck rivets on the interior skins and I am not sure what size drill bit to use on those. Hopefully, someone else will add to this.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 02-02-2009, 09:55 AM   #3
I used a 1/8" drill bit to drill out ALL interior rivets, even the bucked ones. Occasionally the drill bit wasn't big enough and just slipped through the middle of the rivet without drilling it out, and in those rare cases I jumped up to a 5/32.
Old 02-02-2009, 10:44 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We used these as replacements on the belly pan.
Shari
Good afternoon Tubbs Member Introductions 7 11-05-2007 10:29 PM
drill size for Olympic rivets walter1 Ribs, Skins & Rivets 2 09-24-2007 10:09 PM
Trying Gord's Polish this afternoon! Will follow up! cobra93 Cleaning, Stripping & Polishing 52 06-22-2006 05:09 PM
drill size? Stormy Weather Ribs, Skins & Rivets 18 10-17-2004 12:57 PM
What size drill bit for the 1/8 inch in pop rivits? TBKP's Overlander Ribs, Skins & Rivets 3 07-24-2003 11:21 AM
