Old 04-09-2013, 01:09 AM   #1
1958 18' "Footer"
Coburg , Victoria
Help Needed Panel Replacement Method of Replacing
Hi All,
I have a 1958 Traveler which looks as though it may need a rear lower 1/4 panel replaced.
Questions
1 Do you take the old panel off, straighten it out, then mark the replacement sheet and cut it out?
2 Then do you pre drill the new sheet with the rivet holes using the old sheet as a template?
I am just not quite sure about the method you experienced restorers use?
Cheers
bobbygee is offline   Reply With Quote
