Old 04-22-2011, 04:33 PM   #1
mrsfixit's Avatar
1969 31' Sovereign
Twin Lakes , Wisconsin
Images: 21
Help me build my Airstream Tool Box
Which rivets should we have on hand?
Which snips or electric snips?
Which rivet gun?
Any other tools you guys can think of?
1969' 31' Land Yacht Sovereign project
mrsfixit is offline   Reply With Quote
Old 04-22-2011, 04:37 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Oooo, we *love* new tools. I'm eagerly watching what the local vets have to say.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-22-2011, 04:41 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Will this be a traveling tool kit or for restoration.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-22-2011, 04:42 PM   #4
mrsfixit's Avatar
1969 31' Sovereign
Images: 21
Restoration....I guess we'll get into the travel part later.
Old 04-22-2011, 05:56 PM   #5
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I think a lot will depend on what you will actually be doing. You may get a lot of suggestions for things that you really don't need for your situation.
First I would divide it up into the areas, like, frame work, sheet metal work, floor cutting and floor attachment, plumbing, shell work (inc. belly pan), electrical, insulation, interior trim, etc..
The question is kind of generic, like "What kind of car should I buy?". If you live in the mountains.. a Subaru. If you live in the city.. a Subaru. Well, that wasn't a good example.
For me so far the most useful were hammer, pry bar, drill, 4" angle grinder, Skil saw with metal cutting blade, ratchet set big screwdrivers.
The most useful was probably the pry bar.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-22-2011, 06:28 PM   #6
mrsfixit's Avatar
1969 31' Sovereign
Images: 21
Ha ha Daniel! That was a good example. You're right. Ok. I will clarify more:
We HAVE tools for all carpentry, demolition, drywall, some electric & plumbing as well as any civil sewer & water tools.
So I guess I'm looking for those specialized tools for riveting, cutting metal, bending metal, etc.
How's that?
Old 04-22-2011, 06:52 PM   #7
DanielB's Avatar
I'm in the same boat as you. So far I've done some sheet metal cutting with my skil saw and angle grinder. Not the most graceful way to go, I'm telling you.. :-) I think that I can make it through with the saw though. All of the sheet metal work that I'm doing is the belly pan.
I'm having to get a buck riveting kit for the handful of buck rivets, and I'll use the hand riveting gun for the rest, then I'll try to sell the rivet gun and what-not.
- Andrew Carnegie
Old 04-22-2011, 06:59 PM   #8
mrsfixit's Avatar
1969 31' Sovereign
Images: 21
So a buck riveter may be more useful than a rivet gun?? We have both interior, exterior, and belly pan riveting to be done. I was also going to get an electric tin snip/metal cutter tools. I was concerned with the edge it might leave especially in the interior.
Old 04-22-2011, 07:04 PM   #9
DanielB's Avatar
Someone else who knows more should answer about the buck riveting. There are certain places, like the front and rear hold down plates, that should be buck riveted because of the stress.. and the body panels, but from what I understand the pop rivets are ok everywhere else. I'm using pop rivets to attach the lower end of the shell to the C channel. I hope it is ok.
You may not need to buck rivet, depending on what you have to do. You will def. need a gun for pop riveting though.
- Andrew Carnegie
Old 04-22-2011, 07:06 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have a set of these Wiss MetalMaster Aviation Snips, (Straight, Right, and Left Cut) that I bought at Home Depot for way less than shown in the link. That was just the only place I found a photo of all three. Even at Amazon, you can buy them individually cheaper than the set in the link.
The Right and Left Cut models really come in handy even when not cutting curves. For example, when I replaced the original vent in my Excella's bedroom with a Fantastic Vent I had to make the corners of the opening square. Getting the corners squared would have been difficult with the straight cut snips, but using the right and left snips made it a piece of cake. Use the right snips to make one cut into the corner and the left snips to finish from the other side.
Wiss is a quality brand. I also see Klein snips on HD's website now. Klein tools are professional grade tools so you wouldn't go wrong with them, but they may be more costly.
Vaughan
Old 04-22-2011, 08:37 PM   #11
Images: 59
Here's one of about 30 threads on tools. You may want to do your own search on 'tools' in thread title.
Riveting tools
markdoane is online now   Reply With Quote
Old 04-22-2011, 08:43 PM   #12
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
What kind of car should I buy if I have to tow an Airstream? A Subaru. Just open the trunk and strap the tongue to the spare tire!
You really crack me up Daniel!
Lance
Top is offline   Reply With Quote
Old 04-22-2011, 08:52 PM   #13
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Any recently cut edge on sheet metal should be stroked a time or two with a flat file. They're all sharp, no matter what you cut the metal with. Just run the file lightly down the edge, and it becomes much safer to handle.
Old 04-22-2011, 09:01 PM   #14
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
A pneumatic rivet gun sure is nice if you are going to do a lot of riveting
a set of cleco sheet metal holders in the various sizes will help in holding alum sheets in place while riveting. A cleco plier will help install the cleco fasteners. olympic and large flange rivets. 1/8 white rivets for interior work a boat load of 1/8 inch drill bits . a center punch to help start the drill when drilling out old olympic rivets. a rivet head shaver or a drimel tool with a griner tip for finishing the olympic rivets, and and a 4 inch angle grinder to help remove the elevator bolts. This is what I found to be the most useful and oddest of the basic restoration tools.
tracker is offline   Reply With Quote
tools rivets
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
Where not to buy an airstream scorpiontimo Off Topic Forum 25 04-27-2011 05:09 AM
