Old 09-27-2008, 12:04 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
HELP!! does the body of an airstream bulge????
OK I thought the bottom of the body of my AS had slipped of the plywood and frame, Reason being the wall between the kitchen and beds was not all the way to the outside wall.. About 1/2 inch gap. pic bellow....
SO I set up some bracing and jacked up the shell about 1/4 inch and pulled back the inside skin, and saw the body was connected to the frame just fine, nor was there rot in the wood floor..
Plus the inside skin has popped some rivets and pushed a grove in the plywood, like it was cut to long.....
So question is can the body of the airstream start to bulge out a little over the years???
Or can the frame sag on the outsides??? the floor seams pretty level so I don't think this is it!!!!
the body looks Ok from the outside, but I don't think I would notice a 1/2 bulge over the whole side...
Sorry the pic is sideways...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-27-2008, 12:11 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Remember, they were all hand-made and rack in side winds; 1/2" does not bother me.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-27-2008, 01:29 PM   #3
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
My trailer has done the same thing,my wall moved inwards& I had to tap -push,shove it back towards the outer wall.It seems every thing moves a bit ,I removed screws and assorted bits to get the walls back to a semblance ofplumb. That is one of the things I was correcting with my reefer removal.
Diesel1 is offline   Reply With Quote
Old 09-27-2008, 02:54 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
There is one other possibility as a potential cause of bulkhead shifting. Outriggers can fail or become severely weakened by rust resulting in the symptoms you describe. Often, a failed outrigger may push through or cause a dent in the banana wrap, but it doesn't always happen. Two of the curbside outriggers on my Overlander were severely weakened by rust, but didn't damage the banana wraps -- the evidence of the problem was movement of the pantry wall, popped rivets, and a stress crack above the door. Once the outriggers were replaced the pantry wall returned to its original position -- I still have an occasional popped rivet as my axles are in need of replacement.
Kevin
Kevin D. Allen
AIR #827
Old 09-27-2008, 03:19 PM   #5
airstream66's Avatar
1966 30' Sovereign
Bethany , Illinois
Images: 22
Sorry to hijack... What causes the outriggers to poke through the skin?
I think I have that going on right behind the wheel well on the curbside.
Cory
airstream66 is offline   Reply With Quote
Old 09-27-2008, 03:34 PM   #6
Cory
Lack of "proper" running gear balance, causes among other things, the underbelly wrap to flutter, if you wish.
That in turn causes the outriggers to cut the holes that you see.
Old 09-27-2008, 03:34 PM   #7
purman's Avatar
1968 28' Ambassador
Problem is (from what I understand banana wrap being) I don't think I have them.. My utter skin goes all the way down under the trailer... But I will be taking the belley pan off and taking a look this fall sometime I also need new axels at some point... They look a little bent in the middle....
Since it looks structurally sound I don't think I am going to worry about it to much right now... as I need to get some patches in the floor...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-27-2008, 03:39 PM   #8
In addition to what overlander64 pointed out, you can have a cracked frame and/or an axle mounting plate.
The cause of furniture being kicked out from the wall, is about 99.999999 percent lack of proper running gear balance.
It may take years to show up, but it will.
I have never heard of furniture being displaced in any Airstream, that was permanently parked, but I have heard of it, seen it, and repaired the causes of it, for over 40 years.
Proper wheel balance, included the hub and drum and the tire and wheel.
Anything short of that, IS NOT a proper balance.
Old 09-27-2008, 03:41 PM   #9
1966 30' Sovereign
Bethany , Illinois
Images: 22
Thanks Andy,
I have looked at your primmer about axles and mine still have positive angle on the arms. I do have a new hub and wheel on one side, I think the road side rear axle is the one. Could that be causing the Flutter? Is there any cheap way to fix it, strapped for cash right now? I know there are new axles in my future, but not this year.
Cory
Old 09-27-2008, 04:53 PM   #10
Diesel1's Avatar
1967 24' Tradewind
How do you reccomend the balance be done, can a tire shop do it with a on vehicle spin balancer. Thanks, John
Old 09-27-2008, 06:00 PM   #11
Sometimes, a "good" tire shop can do it.
Usually, a "truck" tire shop can do a better job.
Most all tire shops can only balance a tire and wheel.
The old spin balancing can work, but it usually only lasts 3 to 4,000 miles, since a single counter weight is used.
A "very good" balance, uses the heavy spot as a reference, and then places 2 counter weights, 120 degrees from the heavy spot, thus dividing the tire in thirds. That type balancing lasts for at least 10,000 miles, unless the tires get a bald spot from sliding the tires, (brake lockup), or if the axle is out of alignment.
I have been using the two weight counter balance system for over 40 years with great success.
You can see the setup we use, on our web site.
http://www.inlandrv.com/articles/wheel-balancing/
You can click on each photo to enlarge them.
Buying an AIRSTREAM w/ Body Damage? tendegrees Ribs, Skins & Rivets 16 09-28-2017 10:45 AM
Airstream repair to body near Lafayette Indiana t walgamuth General Repair Forum 30 10-02-2011 03:00 PM
Tire bulge versus indentation AZstreamin Tires 11 09-27-2006 08:41 AM
Airstream Body/Repair Shop Kodeman Commercial Listings 21 11-08-2004 09:36 PM
is a 1978 ARGOSY Airstream 28 all aluminum body ? oldvws Our Community 2 12-22-2002 01:46 PM
