Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-14-2004, 09:12 AM   #15
GStephens
GStephens
GStephens's Avatar
Profile:  1982 31' Limited
Hamilton , Texas
No, the head szed dent was made at a SOB repair facility back in February. One of the "repairmen" crawled up on my trailer off a ladder. To this day, I am not exactly sure why he felt he needed to get up on the unit. He initially was on his knees. As he attempted to get to his feet "oops", the pressure of his foot on the unsupported end piece caused a dent to appear where there was no dent before in one of the curved end pieces. I happened to be present when this occurred and just happened to have taken pictures of this formerly dent free area only days before taking it in to this facility. Otherwise, his denial that he had dented the trailer would have probably stood up. As it was, the faqcility's insurance covered the damage.
GStephens
GStephens is offline   Reply With Quote
Old 05-14-2004, 12:09 PM   #16
pinkflamingoes
pinkflamingoes's Avatar
Profile:  1967 24' Tradewind
Alameda , California
Images: 40
I can't believe he denied it! Oh well I thought it might be an interesting story...but it was just a pain in the neck for you and I hope I never end up doing business with that shop.
I'm glad it got fixed.
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 05-18-2004, 08:07 AM   #17
FireFighter
FireFighter's Avatar
Profile:  Currently Looking...
bay city , Michigan
help making the biggest dent smaller
ok all, when i bought this A/S it has this dent the deal was good so i thought i could live with it. after the first year camping with it i am so tired of hearing, did that happen on take off or landing, or watching people grab there kids and go inside their SOB while i park because i must hit things while i backup. Last night we retrieved our A/S from my dad's house and this morning i decided to take on this dent. i know that it will not come out but i want to minimize it. at the point of these pictures i have already pushed 1/3 of it out this is where i have run into the snag. there is the plastic shell from the bathroom in my way. can i safely cut a large hole in this plastic to gain access to this dent? see attached pics
ID:	6662  Click image for larger version
FireFighter is offline   Reply With Quote
Old 05-18-2004, 08:28 AM   #18
j54mark
Profile:
Firefighter,
GStephens was successful because his dent had no creases. Yours has almost nothing but creases.
As Andy noted, you cannot (at least not without equipment and much, much experience) shrink aluminum once it is stretched - and boy is your's stretched. The only road to anything like success is to restore the original shape without any more stretching. This means hours and hours of patient work, pushing gently from behind around and around the outside of the dents (you have mulitiple dents in a single area - each has to be worked out individually), with a tool that will leave no marks. In your case I would estimate the time at something on the order of 30 - 50 hours. Somebody highly skilled and experience could cut that in 1/3.
Once this is done, you will have a pattern of marks from the creases. These can be rendered less noticable by polishing.
Cutting holes in irreplaceable plastic interior panels does not sound like the path to happiness. You can remove the panels, but I think in your case it will necessitate the removal of virtually the entire bathroom.
My first choice would be a new panel (panels? Are two involved?). So would my second and third choice. I think the '76 unit at Colaw's RV salvage is good on that side. Failing that, I think I'd start disassembling the bath.
Good luck,
Mark
Old 05-18-2004, 08:33 AM   #19
FireFighter
bay city , Michigan
cutting hole
the plastic panel that is shown in the picture can not been seen, i removed the large cabinet that hides all of this before taking the pictures. i just wanted to make sure that structurally it shouldn't hurt anything. i know that this dent will never come out perfect without panel replacement, i just want to make it better like i said tired of the attention. PO said that a small tin shed blew into it in a wind storm. wonder how long it took him to come up with that one, looks like a tree to me.
Old 05-18-2004, 08:34 AM   #20
74Argosy24MH
Profile:  LOST , Hawaii
Ditto Mark's post, there is way too much damage to repair. The 1/3 you removed is easy, the creases will be nearly impossible. The lower panel looks like it will pop out once the top and trim is removed, but there is no sense in compounding the work by having to repair interior plastic.
John
74Argosy24MH is offline   Reply With Quote
Old 05-18-2004, 09:25 AM   #21
j54mark
Profile:
There is some structural component to that panel, as there is in all interior panels. How much? ???. I personally would not cut a hole anywhere near as large as you would need.
I agree with John that the lower panel will work out nicely.
Mark
Old 05-18-2004, 09:48 AM   #22
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Fire Fighter.
The lower panel is not dented, but it is "oil canned."
Removing the segment above the quarter panel (lower panel) would allow that quarter panel to easilt pop out.
Pushing the sheetmetal from the inside would almost be a waste of time.
The appearance would not change enough to warrant the trouble, since it is severely creased.
Get a "service manual" from Helen Davis. That manual will show you how to replace segments.
If you "do it yourself" you can cut your overall cost to about $400.00, instead of the ball park $1000.00 to $1100.00 that a dealer would charge.
Locating a "used" segment won't really work, as the rivet holes will be in different places, plus removing a segment correctly, causes more damage to it.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 05-18-2004, 09:53 AM   #23
FireFighter
bay city , Michigan
hmmm
Andy,
will i have to remove the rear bath to replace this segment
Old 05-18-2004, 10:13 AM   #24
74Argosy24MH
Fire Fighter.
The lower panel is dented. Oil can is nearly always on a flat surface, it will move up and down similar to the bottom of the old oil cans often with a pop like they make.
Repair can be done from the exterior on this.
John
Old 05-18-2004, 10:44 AM   #25
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
Are replacement panels like this one avaliable? That would be the only option with that much stretching.I believe they can replace that panel without removing interior panels using olympic rivets.
I keep putting it up on various posts and have not yet got a reply.I have two of the seven segment end cap panels that should be replaced.If they were available I would certainly change them.
greg176 is offline   Reply With Quote
Old 05-18-2004, 11:05 AM   #26
74Argosy24MH
Try Airstream for new, but there will be a very obvious finish mismatch. Used try rv bone yards, not as much mismatch but probably still noticeable with a 40 year old trailer.
John
Old 05-18-2004, 12:13 PM   #27
j54mark
Profile:
Fire Fighter.
One irritation there for many of us is that Airstream will not drop ship segments. I happen to need one now, but my nearest dealer is a 500 mile round trip. So it will have to wait.
Replacing a segment is very interesting. I didn't say fun, but it is interesting. I personally believe the price of $1,000 installed is worth every penny when working on a single segment. I would like to see dealers cut us a little slack when replacing multiple adjacent panels, however.
I also understand exactly what Andy means about used segments, but I am not quite so negative about them. I will say that when using a used segment I absolutely want access to both sides, and I want to buck the rivets. In general, though, new is the way to go if you can.
Mark
Old 05-18-2004, 12:21 PM   #28
FireFighter
bay city , Michigan
installed cost out of range
like often i certainly can not pay to have a seqment installed for $1,000 realistically we are talking about a trailer worth $3000 this is not a good investment. i already know that we hope to upgrade next year so i don't want to be over my head.
Is rest area overnight camping enforced? yukionna On The Road... 12 04-29-2004 05:58 PM
Building in a Computer area in closet JLD General Interior Topics 5 12-05-2003 04:03 PM
Sheboygan, WI Area Vintage Rally 72overlander The Rally Zone 7 07-21-2003 01:13 PM
New VAC club in South East area smily Our Community 11 01-16-2003 06:30 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
