07-01-2015, 09:13 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Heavy corrosion: metal prep?
got some heavy corrosion on the bottom 2" of the rear panel. I'm going to be putting in a doubler, riveted to the solid skin a few inches above. In the mean time, I'm wondering how to deal with the existing corrosion to keep it from getting worse. (maybe it doesn't really matter, since I'll be using a doubler, but it seems as though I should do something).
Anyway, I've seen people suggest the aircraft solutions, alumiprep and alodine, but they're kind of spendy, the smallest available containers have probably 10x what I would need. I got some por-15 metal prep for doing the frame; they say it can be used to prep aluminum for paint, as well, so I'm wondering if this would do a similar job. Their docs say it leaves a zinc phosphate coating. Then I'd hit it with some epoxy primer.
The problem is really only on the skin; the U channel only had some very minor pitting. Since the legs on the U are vertical, and the hold-down plate is angled, the 2 pieces don't really touch; but the back-side of the hold down plate is flat-up against the skin (for much of its height), and the area back there is really bad.
any thoughts appreciated
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
07-02-2015, 11:53 AM
1971 21' Globetrotter
Arvada
For the amount of work to install the doubler you can easily replace that skin. The big issue is that if you don't completely remove the corrosion it will continue to corrode between the C channel and the exterior skin. Do you have the Galvanized angle in there also, because it is also most likely causing the corrosion that is creeping up the skin. if you look at the beginning of my thread below you can see the same issue that I had in the same area.
07-02-2015, 08:04 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
It was galvanized?
didn't look it.
I took it out a couple of days ago...it looked like half the thickness of the skin was stuck to the back of it.
If I were to replace the whole panel, I'd have to re-do the "A I R S T R E A M" letters, and all that...the finish wouldn't match, etc. seems like a major pita.
On the outside of the skin, the corrosion is limited to the area that was covered by the belt line trim. Above that looks like new. clear-coat and all.
On the inside, the same bottom 1 1/2 inches, plus a little more where the hold-down plate was touching.
I prepped the frame for painting today. The label on the metal-prep says its phosphoric acid...leaves a zinc coating.
Air:291
Wbcci: 3752
'73 Safari 23'
07-02-2015, 08:08 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Here's a couple of pics from the outside:
Air:291
Wbcci: 3752
'73 Safari 23'
07-02-2015, 08:13 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Chuck,
I think I'm having deja vu.
I could swear that you asked this question a year or so ago.
Anyway, replace that sheet.
Lance
07-02-2015, 08:28 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
here's what the hold-down plate looked like when I pulled it out:
Air:291
Wbcci: 3752
'73 Safari 23'
07-02-2015, 08:43 PM
Arvada
The rear lower aft skin and structure is the major attach point between the shell and the frame, this area is where the rear separation all starts. If your intent is to still splice than at least do it properly. Cut the entire bottom of the skin off to good metal. The doubler should be one gauge heavier then original, with the doubler picking up two rows of rivets on the new and old skin alike. The rivet spacing should be 6 to 8 rivet diameters apart and you should only use AD rivets. Use a quality sealant and shoot it together wet
07-02-2015, 09:29 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Originally Posted by Top
Chuck,
I'm sure I probably did, and just don't remember.
Oh, well...I suppose if I just cut off the bottom 1 1/2", then I don't really care about the corrosion, right?
Its amazing that the thing was holding together as well as it was. Those rivets were very firmly seated. The skin is soooo brittle, there, though--hard to believe that the skin hadn't cracked around the rivet heads.
Kip: what are AD rivets?
You know, there never was any rear end separation on this one. The bolts going through the hold-down plate were all still intact. Heavy rust, but all still there. there was no movement in the frame at all. The floor had disintegrated long ago...but everything else was there.
Air:291
Wbcci: 3752
'73 Safari 23'
07-03-2015, 10:13 AM
Arvada
They are a tempered rivet with an alloy number of 2117, they have a greatly increased shear load over the "A" rivets used in the shell. I believe that your trailer should already have them installed in the "C" channel to shell interface
07-03-2015, 10:18 AM
1981 31' Excella II
New Market
, Alabama
Paint everything well on the inside to insulate the different metals. The aluminum is an anode to the steel. That is why the aluminum is Swiss cheese and the steel is ok.
Perry
07-03-2015, 04:17 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
hold down was rusty and pitted, but it'll be fine.
Heading out to put the second coat of por-15 on the frame now.
(what a p i t a that is).
do you think "paint" is enough for the hold-down plate? (for insulating the metals). or is there something more/better? rubberized undercoating, etc?
Air:291
Wbcci: 3752
'73 Safari 23'
07-03-2015, 04:48 PM
Always learning
1972 29' Ambassador
Central
Chuck,
I would brush on a layer of Vulkem or another polyurethane sealant as a barrier between the steel and aluminum.
Paint is probably more than what Airstream did in 1973.
Lance
07-03-2015, 05:33 PM
1981 31' Excella II
New Market
, Alabama
POR 15 is pretty good stuff. Won't hurt to wet install rivets with the stuff either. Dip thi rivet in paint then install and buck. Do this on the hold down plate area only or you will have a mess. It will be messy anyway.
Perry
07-03-2015, 06:56 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Second coat of POR is on. what a sucky job that is. I hate painting.
yeah, it didn't look like the hold-down had any paint on it. The side that faced in was just bare metal on the top...not even any rust, where it wasn't touching anything.
Air:291
Wbcci: 3752
'73 Safari 23'
07-09-2015, 08:32 AM
1979 31' Excella 500
Florida
I've got the same issue, ill be replacing the whole panel. About a 2ft x 4ft section. The original panel has a rear access door so i will be getting rid of that to avoid and water issues in the future.
07-09-2015, 09:32 AM
Arvada
Good plan, with a Florida trailer you can expect some frame damage too
07-09-2015, 09:40 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
do you suppose its possible to get a NOS panel, that has the appropriate clear coat?
Air:291
Wbcci: 3752
'73 Safari 23'
07-09-2015, 11:03 AM
1981 31' Excella Limited
Ojai
Similar problem 31 Excella
About a month ago got a '81 Excella- 31, and have begun repairs. I've got the same problem with corroded bottom 2" of outside skin at rear, but also cannot see anything of the vertical struts/studs that should be connecting the inner/outer skin to the floor across the full 6 feet of the straight area of junction between wall (under window) and floor. this is a center bathroom model. This trailer was rear-ended on the freeway when still under prior owners usage. Outside skin damage was almost non-existent and I can only assume that the vehicle running into the trailer must have gone up underneath the rig. The accident resulted in destruction of rear bumper and main frame members being bent up. Prior owner had already cut out damaged frame members and re-welded straight replacements. He also removed damaged flooring in rear bedroom and put in new plywood, and on top of that wood laminate flooring. My plan is to remove the inner skin under the window and see what is going on there. Clearly something is missing, but not knowing much about AS's I'm not likely to know what is required there. Any help out there?
07-09-2015, 11:14 AM
Arvada
Once you get the inner skin removed, take a picture and post. You might also want to start you own thread with your adventure.
Welcome to the Airforums
