Old 07-09-2015, 08:32 AM   #15
SpitFireRX's Avatar
1979 31' Excella 500
Florida , Florida
I've got the same issue, ill be replacing the whole panel. About a 2ft x 4ft section. The original panel has a rear access door so i will be getting rid of that to avoid and water issues in the future.
SpitFireRX is offline   Reply With Quote
Old 07-09-2015, 09:32 AM   #16
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Good plan, with a Florida trailer you can expect some frame damage too
Old 07-09-2015, 09:40 AM   #17
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
do you suppose its possible to get a NOS panel, that has the appropriate clear coat?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-09-2015, 11:03 AM   #18
1981 31' Excella Limited
Ojai , California
Similar problem 31 Excella
About a month ago got a '81 Excella- 31, and have begun repairs. I've got the same problem with corroded bottom 2" of outside skin at rear, but also cannot see anything of the vertical struts/studs that should be connecting the inner/outer skin to the floor across the full 6 feet of the straight area of junction between wall (under window) and floor. this is a center bathroom model. This trailer was rear-ended on the freeway when still under prior owners usage. Outside skin damage was almost non-existent and I can only assume that the vehicle running into the trailer must have gone up underneath the rig. The accident resulted in destruction of rear bumper and main frame members being bent up. Prior owner had already cut out damaged frame members and re-welded straight replacements. He also removed damaged flooring in rear bedroom and put in new plywood, and on top of that wood laminate flooring. My plan is to remove the inner skin under the window and see what is going on there. Clearly something is missing, but not knowing much about AS's I'm not likely to know what is required there. Any help out there?
Lee Prather is offline   Reply With Quote
Old 07-09-2015, 11:14 AM   #19
Aerowood's Avatar
Arvada , Colorado
Once you get the inner skin removed, take a picture and post. You might also want to start you own thread with your adventure.
Welcome to the Airforums
Tap screws and metal prep Muskie Repairing/Replacing Floor &/or Frame 2 01-21-2014 06:04 PM
Dissimilar Metal Corrosion JIM Bowers Exterior Restoration Forum 1 01-26-2006 04:15 PM
Dissimilar metal corrosion Safari Tim Ribs, Skins & Rivets 21 05-17-2005 02:22 PM
Remote Generator Prep Porky Pig Generators & Solar Power 11 05-18-2004 10:53 PM
