Old 04-26-2011, 07:10 PM   #1
Rivet Master In Training
Kevo's Avatar
1965 22' Safari
Mount Airy , Georgia
Send a message via AIM to Kevo Send a message via MSN to Kevo Send a message via Yahoo to Kevo
Heater Hole Patch....
Looking for some suggestions, I am replacing the furnace in my 65 Safari, I am considering one from a later model Airstream. The new furnaces have the much smaller intake and exhaust ( the small rectangular plate with the 2 holes in them ). I was considering just putting a patch over the existing hole and making smaller hole in the patch for the new intake and exhaust plate. I have not done any riveting as of yet, and a little leery. Any other creative suggestions ?
Kevo is offline   Reply With Quote
Old 04-26-2011, 07:31 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My hole was not as big as yours, but I patched it with a square patch, and the exhaust for the new heater ended up right above it. It looks fine, nobody notices unless they are looking for it. It wasn't very hard to do either. I just sealed it with a bead of vulkem and riveted it on.
Stephanie
Old 04-26-2011, 07:37 PM   #3
Ottawa , ON
That's the trick isn't it? Apart from that, you could cut the AL in the shape of Texas, or a heart and make it more decorative, but a patch is a patch.
Old 04-26-2011, 07:51 PM   #4
Kevo's Avatar
1965 22' Safari
Stef, what kind of rivets did you use ?
Old 04-26-2011, 08:05 PM   #5
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Now there is a flash of creativity.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-26-2011, 08:11 PM   #6
DanielB's Avatar
Well.. it looks like you are going to have to patch it. Aside from appearances, I'd be wary of possible leakage.
The pop rivets have the mandrel (stick) thing in the middle and a hole on the face where water can get in. Pop rivets are solid but require a whole setup to do.
No really great choices.. unless.. there really is a creative solution.
- Andrew Carnegie
Old 04-26-2011, 08:14 PM   #7
Ottawa , ON
Buck rivets don't look like an impossibility, given that the inner shell is already off in that spot (from what I can see in the photo).
Failing that, rent a rivet shaver and go with Olympic rivets.
Old 04-26-2011, 08:32 PM   #8
Kevo's Avatar
1965 22' Safari
I thought about going Olympic, but who rents the shavers ? those darn things are expensive !!
Old 04-26-2011, 08:37 PM   #9
DanielB's Avatar
Looks like out of doors mart will rent it for 30 days for about $35.
Olympic Rivet Dresser Rental HS310-5B-R [HS310-5B-R] - $249.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
- Andrew Carnegie
Old 04-26-2011, 08:41 PM   #10
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I used olympic rivets and cleaned them up with a dremel tool, and then went to a rally where one of our unit members had a rivet shaver and he cleaned them up proper for me. Though if you have a steady hand, you can probably do a very passable job with a dremel, just don't let it bounce off onto the panel around the rivet!
Stephanie
Old 04-26-2011, 08:48 PM   #11
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I found before and after pictures. This was a couple years ago, now the 'newness' of the patch has worn off and it doesn't stand out as much.
ID:	128287   Click image for larger version
Stephanie
Old 04-26-2011, 09:19 PM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have successfully 'shaved' my Olympic rivets with a Dremel grinder. Take your time and you can't tell the difference as if you had used an expensive shaver.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-27-2011, 10:11 PM   #13
2007 25' Safari FB SE
Eureka Springs , Arkansas
Kevin,
I had a similar problem last year. Our coach was set up for commercial display, and had the furnace door, but furnace was removed. We wanted to relocate furnace, so I found a mobile RV mechanic to install new furnace in new location.
I was left to patch the hole. Thanks to advice on this column, the following pics show what I did.
I laid out rivet spacing on the patch with a divider, so spacing is consistent. I then drilled all holes in patch on drill press.
Next step was to locate patch and drill holes in coach. I temp fastened patch with screws. (Picture shows tape in place, but remove it before riveting.)
Next, spread Vulcum over mating surfaces and rivet with Olympic rivets.
I nipped off ends and then masked the surrounding area in case of a slip up, and carefully smoothed rivets with small wheel in drill. I then touched them up with a file.
All is well!
PS!! Hideous graphics are gone! Her exterior looks like a normal AS now!
ID:	128398   Click image for larger version
ID:	128400   Click image for larger version
triplenet is offline   Reply With Quote
Old 04-28-2011, 01:42 AM   #14
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
That is a nice looking patch!
Stephanie
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Framing for New Water Heater Opening silver-man 1960 - 1964 Overlander 3 04-25-2011 11:17 PM
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 04:46 AM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
