Old 09-16-2015, 05:37 PM   #1
Fayetteville , New York
Having Issues Removing Paint From Skin
I am using Rust-oleum Aircraft remover to strip the skin on my trailer. It takes the paint off but there is some other layer of "something" that won't come off with the remover. It is yellow. Any suggestions on what it is and how to remove it without damaging the aluminum?
[/URL][/IMG]
Whalensdad is offline   Reply With Quote
Old 09-21-2015, 03:20 PM   #2
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Zinc Chromate primer? Maybe? IF so, not sure why it won't strip. It is great stuff but not used much any more and I'm not sure if it can even be bought via retail.
https://en.wikipedia.org/wiki/Zinc_chromate
Howard L. is offline   Reply With Quote
Old 09-21-2015, 03:26 PM   #3
Howard L.'s Avatar
San Antonio , Texas
Old 09-21-2015, 03:40 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Don't believe everything you read on Wiki.
Still available from Rustoleum and many other sources.
High Performance - 7400 System Zinc Chromate Primers
MICHAEL
Old 09-22-2015, 04:58 PM   #5
Howard L.'s Avatar
San Antonio , Texas
That's good. Wonder if it is the same powerful primer from those years ago? It may be the same, I just wonder if it's watered down. Most EPA attacked products end up banned or weak substitutes.
Any ideas why I am having shipping issues? martin300662 Argosy Motorhomes 17 08-20-2014 01:44 PM
Is forum mobile having issues? cwf Forum Admin, News and Member Account Info 1 09-09-2013 09:39 AM
Having trouble removing old rock guard frame silversistas Rock Guards, Segment & Window Protectors 4 07-17-2012 06:57 PM
I am having problems removing flange from black tank bennyg Waste Systems, Tanks & Totes 11 07-08-2011 07:19 AM
Having brake pedal issues and may need rotors SilverToy Brakes & Brake Controllers 10 06-25-2007 04:43 PM
