Old 04-22-2016, 12:27 PM   #1
2016 23' International
Newhall , California
Hard water spots on exterior aluminum - How to remove?
Does anyone have proven help to reduce or prevent hard water spots on exterior aluminum skin?
thanks
Robert
whitefoot@ca.rr.com
Robert24341 is offline   Reply With Quote
Old 04-22-2016, 12:36 PM   #2
dznf0g's Avatar
Oswego , Illinois
Wax once in awhile and chamois after washing.
-Rich-
Old 05-04-2016, 09:40 AM   #3
Boxite's Avatar
2008 22' Sport
The water spots are likely calcium in the water source. Two ways to deal with it.... 1) add a little vinegar to water to rinse... 2) use a water-softener product such as dishwasher product like "RinseAway".
Be aware that vinegar is acetic acid diluted to about 5%. Any bare aluminum may develop an appearance like dull anodizing, so dilute it as much as necessary to remove the spots.
Another solution is to back-away from the AS when viewing it.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 05-17-2016, 06:37 PM   #4
SanAndVin's Avatar
2017 16' Sport
San Diego and Julian , California
Hard water spots are a pain, but I have found a product that worked like a charm when nothing else did. Meguire's, like in the car wax products, has a compound called Water Spot Remover.
Slip Sliding in Air,
Sandy, Andrew, Vince
SanAndVin is offline   Reply With Quote
Remove rust spots ericpeltier Vintage Kin 3 07-17-2015 10:43 AM
How hard to redo aluminum interior end caps? badpaddler Upholstery, Blinds, Walls & Interior Finishes 9 04-06-2015 11:18 AM
Compound Polish Won't Remove Water Spots? bredlo Cleaning, Stripping & Polishing 16 04-24-2014 02:15 PM
Remove water-spots from removALL/Citristrip DustDom Our Community 3 06-21-2012 07:14 PM
Water spots...how to remove or prevent? Rog0525 Cleaning, Stripping & Polishing 1 07-11-2004 04:54 AM
