Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-29-2008, 09:00 PM   #1
Sunset Coast
Sunset Coast's Avatar
Profile:  1988 32' Excella
Benton Harbor , Michigan
Hand riveter tool
I am trying to find a hand riveter tool for 1/8" pop rivets that has only about a 3/8" diameter barrel so I can mount the segment protector brackets to my AS. The "hat" shaped brackets have the holes very close to the body of the bracket and my regular rivet hand tool is too large to reach the holes.
Anyone seen a tool like this with the small diameter barrel?
Thanks, Doug
Name:	March 2008 013-2.jpg
ID:	57250  Click image for larger version
Name:	March 2008 015-2.jpg
Sunset Coast is offline   Reply With Quote
Old 03-29-2008, 09:25 PM   #2
bkahler
Profile:  Jefferson , Arkansas
I've run into a situation like that before and I ended up using a small hollow spacer slipped over the stud of the rivet. If I'm not mistaken the stud is designed to break off down inside the rivet body so spacing it up doesn't matter. I've found various spacers at Home Depot and Lowe's in their hardware section. You could even try #10 washers stacked up high enough to provide clearance. Just be aware that once the stud snaps the washers are going to go flying!
Basically anything that will fit in the area and still keep the rivet gun out of the way should work.
Good luck!
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
bkahler is online now   Reply With Quote
Old 03-29-2008, 09:53 PM   #3
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove , California
Try using a small 1/4" drive socket as a spacer. Perhaps 3/16, with the drive end up toward the rivet tool.
Jim Foster is online now   Reply With Quote
Old 03-30-2008, 06:43 AM   #4
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
You can stack a few of the backing washers they sell to reinforce the blind side to make the extension - I have boxes of them in the pop-rivet tool kit already and they work well. If it's just a little interference leave the mandrel bushing a few turns loose to get the extra 1/8" if it's just for a few rivets...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Wabbiteer is online now   Reply With Quote
Old 03-30-2008, 09:49 AM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Try grinding the head of the rivet gun down to the size you need to fit next to the bracket. I've done this with great success for a number of specialty applications. If you have a high quality rivet gun, buy a cheapie for this purpope only and save your good one.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-30-2008, 05:02 PM   #6
Sunset Coast
Solved !
Thanks everybody for the ideas. I was able to use a small spacer and still get a grip on the rivet shaft. It worked great ... the spacer occasionally went "flying" when the shaft popped! Thanks again.
Threads that have gotten out of hand... Andy R Official Announcements 0 02-12-2007 04:59 PM
Hand Dollies -- Anyone Use One BillM2 Towing, Tow Vehicles & Hitches 35 12-08-2006 08:54 AM
Air hydraulic riveter ($30) COUPON** Wabbiteer Ribs, Skins & Rivets 3 07-20-2006 10:41 AM
Any idea where to find a skilled, mobile buck-riveter? 1959newbie Ribs, Skins & Rivets 15 06-10-2006 08:06 AM
Stanley Riveter BobbyW Ribs, Skins & Rivets 4 05-12-2002 07:29 PM
