Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-04-2003, 05:08 PM   #1
68 Suburban
68 Suburban's Avatar
Profile:
Hairline Crack in Aluminum.
I have a very thin hairline crack in my aluminum near the corner of the wheel well. It is very thin and only about a 1/2 inch long. I don't want it to get any longer. Would a temperary fix be to drill a small hole on the end of the crack? I heard that will stop the crack from spreading. Thanks for any advise.
Here is the link to Dingo's trailer:
1968 Avion T-22
68 Suburban is offline   Reply With Quote
Old 03-04-2003, 08:52 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Drilling holes is the way to stop cracks on an aircraft and should also work in your case. I would then pop a rivet in the hole and no one would ever be the wiser.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 03-05-2003, 10:11 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Stopping a crack is one thing.
Findout out what caused it, and then fixing that problem, is the best way to stop the crack from getting worse.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 12:17 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
Aluminum floors? Janet All Argosy Trailers 2 01-26-2004 08:05 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
test
