Old 06-04-2011, 08:57 PM   #1
1967 26' Overlander
seagoville , Texas
Hail damage help.
Has anyone had any luck with getting small hail dings out of trailer skin, if so what did you use? Will appericate any help. Thanks Paula
paula grant is offline   Reply With Quote
Old 06-04-2011, 09:09 PM   #2
1985 31' Excella
Fresno , Texas
You have to deal with them very quickly. The longer it is dented the less chance you have on getting them out. In the hot part of the day (trailer in the sun with dents being worked aligned with the sun direction put a piece of dry ice on the dent.
Wsmith is offline   Reply With Quote
Old 06-04-2011, 10:28 PM   #3
Paula.
Many years ago, I was the "special representative" for the insurance division of Aistream, that was Called Caravanner Insurance company.
Part of my job was to evaluated the type and degree of damage to an Airstream from hail, and to make a settlement with our insureds.
Long story short, LEAVE THE TRAILER ALONE.
The sides and roof of your 67 were made with tempered stress relieved aluminum, namely 2024T3.
Most all the hail dents in the flat sheets, will disappear in a matter of months, as long as the trailer is exposed to the sun. The segments, thats the compound curved pieces of metal, that your trailer has 5 of them on the front and back, are made with a softer aluminum, therefore those dents will most likely remain forever.
You cannot heat the metal, nor can you freeze the dents. Just leave them alone, but take some close up photos of some of the damage. After a few months of sun shine on the trailer, when you check out those areas, you will see that many of the dents are GONE."
Some say hogwash, and some that know me from years ago, will vouch that the dents will disappear.
Incidentally, I settled over 1000 (one thousand) hail loss claims for Caravanners, in just 4 years.
Replace those parts that may be broken or damaged, but again, "leave the shell alone".
You will witness "MAGIC" from our sun on your Airstream.
Old 06-05-2011, 04:35 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When I found my 71 it had been sitting in a field for many years. It came with hail texture so I don't worry too much. I do not have a shelter for it though and do worry about those baseballs we hear about more often. Global warming?
Old 06-05-2011, 06:18 AM   #5
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Global warming, it's for real.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 06-05-2011, 06:32 AM   #6
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Thumbs up Too True!!
I just experienced your comment first hand. We were stuck in a storm West of Fort Worth and my wife's Honda received $3,500 worth of damages, my vintage truck didn't receive a single dent (made of real metal), but our Airstream got pounded. Immediately after the storm there were probably more than 3,000 dents on the roof and 50 on the back side curves and near the back window from when the wind shifted and the hail went sideways.
Just after the storm, three catastrophic insurance teams parked next to us in the rv park we are staying at to work claims on houses caused by the hail.
A Sportsman travel trailer and two ex-FEMA trailers also got pounded and they lost their rear windows when the wind shifted. They received major dents on the rear side and the roof areas. Those three trailers look the same now as they did the day after the storm. Their aluminum did not fix itself (cheaper, thinner materials??)
Our Airstream has repaired itself to a point that I would not believe if I didn't see it with my own eyes. I can only see 4 dents in the roof....yes 4. About 10 of the rear corner dents are still viewable, but I'm o.k. with those (gives it character scars from the experience). I am just amaized at the self-reforming of the metal.
You sure know what your talking about Andy and thanks for all of your valuable input in this great forum.
Tharon Neal
mopariac is offline   Reply With Quote
Old 06-05-2011, 06:48 AM   #7
fmrcaptevil's Avatar
Weldon Spring , Missouri
When did they start using cheaper metal?
fmrcaptevil is offline   Reply With Quote
Old 06-05-2011, 07:50 AM   #8
In 1982 1/2 Airstream switched to a "dull metal" for appearance.
In the 90's, they switched again.
Cheaper metal? NO WAY.
Different appearance, YES.
Old 06-05-2011, 08:57 AM   #9
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
I didn't mean cheaper Airstream aluminum...I meant the square trailer aluminum was thin on the Sportsman and the ex-FEMA trailers. The dents are still in those trailers.
Old 06-05-2011, 10:47 AM   #10
Trailers like that are made with a soft .019 aluminum. They show everything, forever.
Airstreams are made with considerably harder metal and is either .032 or .040 thick, depending on the year.
Airstream uses the aircraft type construction which is called "monocoque".
However since Airstream uses a simple frame, their construction is called "semi-monocoque".
Contrary to some opinions, the Airstream shell, "holds up" the frame. Therefore the frame can be weak.
Box trailers use the frame to hold up the shell. Because of that, their frame must be very strong.
Some owners, that had the "rear end separation" on their Airstream, want to beef up the frame. WRONG.
That additional weight will make the frame separate from the shell even faster, unless many more hold downs are added, to keep the two together.
Old 06-05-2011, 11:01 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Back in the 1980's, Airstream went to a thicker, softer aluminum that was easier to work with without fatiguing. Because the "new" metal is softer, it is easier to dent.
Old 06-05-2011, 11:44 AM   #12
1967 26' Overlander
seagoville , Texas
Thanks for all the information, I think I will Take Andy advice and just let mother nature fix what she has done and just live with what she can't fix. It's great to live in texas where it might snow tomorrow!!! Thanks Paula
Old 06-05-2011, 12:06 PM   #13
Goal15's Avatar
Dallas , Texas
Snow in Seagoville tomorrow?
Paula, you've just got to stop believing everything Pete Delkus says lol
Goal15 is offline   Reply With Quote
Old 06-05-2011, 12:41 PM   #14
Paula.
Please report back to the Forums, after this summer is over, and for the benefit of others, let them know much of the dents, disappeared.
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Survived the Hail and Wind Storm! Rv-Voyager On The Road... 4 05-25-2011 11:08 AM
Help, where is the 12V fuse box hidden???, 1992 34 ft. Limited, Tornado Damage frankfarmer General Interior Topics 2 05-09-2011 09:30 AM
Hail Damage to Roof Panels dgilchrist44 Roof 0 03-21-2011 05:16 PM
how do I diagnose frame damage on '59 18-footer cindy Repairing/Replacing Floor &/or Frame 0 03-11-2011 01:43 PM
