Old 08-10-2004, 11:19 AM   #15
1993 30' Excella
1969 18' Caravel
Lovettsville , Virginia
Hi Richard
New member here. I'm the 3rd owner of my '93 Excella and was able to speak to the second owner, who told me the original owner (sorry, bear with me a min here - lol) attended the Bismarck rally in '93. The hail damage to the trailer was over $10K, with the street side panels replaced only - the top panels were left untouched. When I'm on a ladder I can see evidence of hail damage on my roof, but it is not severe at all and can't be seen from the ground. Hopefully your damage will work itself out over time.
takenitez is offline   Reply With Quote
Old 08-13-2004, 01:08 PM   #16
Andy,
Thank you. State Farm did provide a very detailed estimate (panel by panel and part by part).
Thank you for your response.
Sid
Sid.
You demonstrated the point. Your trailer was hit with hail, but only the segments show damage. The segments are a softer material, which allows them to be stretch formed.
Therefore, some of the dents will dissapear in the segments, but it's unlikely they all will.
A loss of value settlement should be "very specific." Each and every damaged panel should be listed, and the allowance for each one.
In that way, should you have collision damage to one of the same panels, State Farm will deduct the amout of the loss of value.
Should it not be itemized that way, then it's anyones guess as to how much they would deduct for that particular panel, in the event of a collision loss.
Exact itemization, is the "key." Don't accept less.
If the adjuster knows what he's doing, you won't have a problem.
soscott is offline   Reply With Quote
Old 08-13-2004, 07:46 PM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends
Originally Posted by steelbird312
Yes, Lynn, in your old MG, unless I am very badly mitaken, the hood was steel, and I would expect that indeed it would have tried to resume original shape under the heat. It will be interesting to see if we hear from any of those who actually experienced it.
jerry
Jerry,
Depends on the year and model of MG. Several of mine had aluminum hoods. Mostly the 65-67 model B's.
Aaron
WBCCI #XXXX AIR #2495
Old 05-18-2015, 12:13 AM   #18
2015 27' FB International
Mary Esther , Florida
Andy could you call me about Hail damage Don 334-294-7000 2015 FB27
Grateful2 is offline   Reply With Quote
Old 05-23-2015, 07:07 PM   #19
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Paintless dent repair guys use hot glue and small dent puller hardware to remove dings, dents, small hail damage when they can't get in behind the area. Works well on out trailers. Remove the hot glue with alcohol.
Howard L. is offline   Reply With Quote
Are Those RV Covers Any Protection at All Against Hail Damage ?? MileHigh Off Topic Forum 3 07-16-2004 10:36 PM
fire damage in water heater area mtpalms Interior Restoration Forum 2 04-06-2004 05:43 PM
Urgent: frame damage caused by improper jacking? Rog0525 1969-1971 Caravel 39 03-31-2004 05:35 PM
Hail Damaged Excella 35...... longhauler 1987 - 1989 Excella 17 07-28-2003 08:38 AM
Hail Damage jcanavera Our Community 4 03-30-2002 09:24 AM
