Old 06-14-2014, 10:33 AM   #1
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Hail damage
We have recently received hail damage on our airstream. Any suggestions? Any way we can deal with minor damage ourselves?
Gege
GeGe is offline   Reply With Quote
Old 06-14-2014, 10:37 AM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Too bad about your hail damage. Have you talked to your insurance company? The only thing I can think of is one of the paint less dent repair shops but they will need access to the backside of the dents, other than that it panel replacement.
Good luck
Mike
desertair27 is offline   Reply With Quote
Old 06-14-2014, 10:44 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have read on this forum that much of the hail damage that happens on surfaces not subject to compound curves comes out on its own through time and heat cycles.
Is it true? I don't know.
Old 06-14-2014, 10:55 AM   #4
Hail damage to the segments will not go away.
However, the same hail damage to the side and roof sheets, in time, will disappear.
Leave the trailer in the hot sun during this summer and watch the dents slowly go away.
How do I know.
I took care of over 1000 hail damages losses when I worked for the old insurance division of Airstream.
The segments should be replaced, by the insurance company, and the damage to the long panels should be on as "loss of value" basis.
Old 06-14-2014, 11:07 AM   #5
SteveH's Avatar
Common Sense , Texas
It has been my observation that small hail dents in Airstream flat panels do indeed diminish with time and heat, but if they are large, you will always be able to see them.
Dents in the compound curved caps will never go away without panel replacement. In the Dallas/Ft Worth area, North Dallas RV is capable doing this kind of work.
Good luck with your insurance company and repair.
Regards,
Steve
Old 06-14-2014, 04:56 PM   #6
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Thanks so much. Luckily we will have a lot of over 100 degree days coming up. Gege
Gege
Hail damage shaman Ribs, Skins & Rivets 18 05-23-2015 07:07 PM
Hail Damage stratosboat1 Member Introductions 31 05-23-2006 07:42 AM
Hail, Hail and we're still here GreggH Off Topic Forum 10 04-09-2006 06:48 PM
Are Those RV Covers Any Protection at All Against Hail Damage ?? MileHigh Off Topic Forum 3 07-16-2004 10:36 PM
Hail Damage jcanavera Our Community 4 03-30-2002 09:24 AM
