Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-07-2017, 12:11 AM   #1
FlyingCloud3's Avatar
1950 21' Flying Cloud
1960 22' Safari
Newland , North Carolina
Gull Wing Door: Looking for tips & suggestions
I am interested in building a roughly 3' x 8' gull-wing door in one side on my 1960 Safari, similar to this:
I am wondering what my options are for fabricating the curved studs.
And I'm not sure what kind of stock to use to make the frames.
And there are many other details like seals, hinges, door lifting struts, latches, etc...
I would appreciate any suggestions folks might have.
Thanks!
Ryan Franks
1974 Sovereign Land Yacht 31'
1950 Flying Cloud 21'
1960 Safari 22'
Newland, NC
FlyingCloud3 is offline   Reply With Quote
Old 06-07-2017, 05:27 AM   #2
2017 Basecamp
Bennington , Vermont
Have a look at
http://www.stonewellbodies.com
They've been manufacturing tig welded all aluminum custom truck bodies and trailers for the farrier and vet industry for a long time.
If nothing else you'll have some good creative fodder. Lots of detailed pics.
If you had a preexisting straight stud you could pie cut it, bend it, tig weld the cuts back together and voila. All you'd really need is the radius of the curve, length of curve, etc. plug those into your favorite cad software n let the computer figure out your cuts.
Hope that helps.
Those of us who do what we do, do what we can
gouchodon is offline   Reply With Quote
Old 06-07-2017, 06:34 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
OP, you might want to consult with one of the companies that does Airstream foodcart conversions or directly with AIRSTREAM. Last time I visited Jackson Center they had several European foodcart models on the assembly line.
MICHAEL
Old 06-08-2017, 10:45 PM   #4
1960 22' Safari
thanks for the ideas!
those vet/farrier bodies are really nice!
It's cool to incorporate some solid aluminum components with these custom projects.
I like the idea of using some square tubing for the framing of the door itself if I can figure out how to bend it. I'm hoping I can just heat it up and work the curve into it by pulling it against a makeshift die with a little leverage.
I will talk to some of those great fabricators out there and see if they can point me in the right direction.
Thanks again!
Ryan Franks
1960 Safari 22'
Newland, NC
Tips or suggestions for our DC - Nevada roadtrip? pennstate95 Sprinter and B-van Forum 10 07-30-2014 06:39 PM
Timeless Custom Gull Wing Airstream Brett - TTT Commercial Listings 23 03-17-2011 01:33 PM
Carpet replacing tips / suggestions?? bpcaudill Floor Finishes 3 10-17-2008 01:42 PM
Road Trip, Tips & Suggestions welcome! JimHoek On The Road... 6 10-16-2007 09:15 AM
