Old 11-04-2008, 11:40 AM   #1
Alumanutz's Avatar
1966 22' Safari
Chico , California
Golden Rivets
Soon I will be replacing the Olympic rivets on my trailer with bucked rivets. I already have the replacement rivets. They have the "Gold Coating" on them. I have read on the forum that this coating will polish off. My question is will it do any harm to put these in my bullet polishing tumbler and clean them off before installation. What is the purpose of the coating?
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Old 11-04-2008, 11:47 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
NUTZ
Greetings NUTZ- Hmm...... I have a brass casing tumbler, never needed to polish my bullets. Well maybe my silver tips when the October moon is full. If you used corn husk I think it would do an awsome job. Not sure why the coating, I too would like to know its purpose.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-04-2008, 12:13 PM   #3
NUTZ
The gold finish is called "Alodine".
It's primarily used by the aircraft industry.
To replace the olympic rivets properly, you will need 5/32 diameter rivets, since the diameter of the olympics is 5/32".
The proper drill bit size is a # 21 drill bit.
Old 11-04-2008, 01:48 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I believe they are coated to protect them from oxidation from the time they are manufactured.
The Alodine finish comes right off - very easily. Actually, the act of bucking them takes off some of it...and the rest kinda fades with the weather, what's left can be removed with the first pass with a buffer - probably even by hand if you aren't doing a full polish job. However, I can't see that tumbling them would be a problem - unless they are soft enough that the tumbling would damage the edges - the edges are pretty thin.
Shari
Shari
Old 11-04-2008, 01:59 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
To replace the olympic rivets properly, you will need 5/16 diameter rivets, since the diameter of the olympics is 5/32".
5/16 diameter rivets? I shot some a few years ago, I had to use a 9X gun and a piece of railroad track to buck them. All funny aside I thick Andy made a typo as it should be 5/32.
Kip
Old 11-04-2008, 05:38 PM   #6
Alumanutz's Avatar
1966 22' Safari
Chico , California
Kip, I hope you are correct. A quick look shows a #21 drill is .1590
A 5/16 rivet is a .3125 dia
I think that sucker would be pretty well mushroomed just trying to get it through the hole!
NUTZ
Old 11-04-2008, 05:57 PM   #7
Kip
I did say 5/32"
Old 11-04-2008, 06:16 PM   #8
Alumanutz's Avatar
1966 22' Safari
Chico , California
Sure looks to me like 5/16th. I added the red.
NUTZ
Old 11-04-2008, 06:36 PM   #9
Images: 59
I don't see the problem. It's the head diameter, not the stem.
Old 11-04-2008, 09:34 PM   #10
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Most days this beats the comedy channel.
Diesel1 is offline   Reply With Quote
Old 11-05-2008, 04:21 AM   #11
Baltimore , Maryland
John...#21 bit for sure. Don't bother tumbling, the polisher will take the coating right off. Do your rivets have numbers stamped in them too? That is the thing that bothers me, but quickly you stop seeing them.
Old 11-05-2008, 07:30 AM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
Lightbulb
We have slightly shaved our bucked rivets with the numbers on them. It makes the edges a little softer so they show even less once polished. Got to be careful not to go to deep though - the shaver will leave a bit of a ridge if you do...but can be polished smooth if you do with a bit more effort.
Shari
Golden Access Passport Card rseagle On The Road... 3 09-10-2006 09:37 AM
Golden Anniversary monument ceremony streamer23 WBCCI Forum 0 08-17-2005 06:24 PM
Behold, the Golden Airstream... idahosafari Our Community 6 10-10-2003 11:01 AM
Golden Avion - what is it? JimC Our Community 2 05-12-2003 02:11 PM
