Old 02-16-2014, 12:01 PM   #1
Darlington , South Carolina
General question from a newbie about exterior "level"
Any suggestions for a good replacement for this exterior level? I am a proud new owner if a '78 Sovereign and am beginning restorations on a small scale for now.
jrussjr is offline   Reply With Quote
Old 02-16-2014, 12:59 PM   #2
aftermath's Avatar
Spokane , Washington
You can get something very similar to this at almost any trailer supply store. The challenge will be installing it so that it accurately displays true horizontal.
aftermath is offline   Reply With Quote
Old 02-16-2014, 01:11 PM   #3
Ag&Au's Avatar
Port Orchard , Washington
Keep in mind that accurate leveling is not as critical as most would think. In most cases, if it feels level inside the trailer, it is close enough. I use these:
RV Levels, Set of 2 - RV Designer E401 - Levels - Camping World
They don't require mounting holes (or you may use screws if you desire) and can be removed without leaving scars with a bit of cleaning (if you don't use screws).
They have the advantage of the mounting tape being somewhat flexible, so you can make it read level even if it is not exact.
Don't be surprised if your question develops into a discussion (argument) about how level you should or must be. Personally, I think exact leveling is overrated.
Ken
Old 02-16-2014, 01:30 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Ken, I an laying in bed getting ready for a nap angled slightly downhill....
So I agree,
Sleeping uphill kind of sucks though.
Old 02-16-2014, 01:38 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Attachment 205715
The Master Level was standard issue on most Airstreams for many years, and are still easily available as already mentioned. I really like mine.
They need to be installed with the help of a carpenters level the first time, on a fairly level pad. They have adjustments for the left to right leveling as well as the front to back.
A new one will likely attach in the same holes as the original.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is offline   Reply With Quote
Old 02-16-2014, 01:45 PM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
The only real reason to level is for the refrigerator when in propane mode. The more level, the more efficient the cooling action. It's the cooling plate inside the freezer that needs to be level in both directions.
Silver Hawk is offline   Reply With Quote
Old 02-16-2014, 02:08 PM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I just use a carpenters level and wife talks to me through walky talkie - but something mounted could be cool
I forgot to check the level on our second trip and it did not bother me - until I made pancakes the next morning - then I felt like Lucy in long long trailer
PharmGeek is offline   Reply With Quote
Old 02-16-2014, 02:28 PM   #8
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
I have 4 of the stick ons that Ken recommended. Two at the front left corner so I can see both side to side and front to back in the same place one near the door and one just above the license plate at the rear. They are small enough to be unobtrusive, large enough to read and graduated in inches so you can count the blocks you need for side to side leveling.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 02-16-2014, 03:01 PM   #9
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Oh gosh, I park, step back, eue it up and decide which end my head will be on the bed, so far it works for me. Btw, mostly boondock and fridge ok.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 02-16-2014, 07:36 PM   #10
Cannonball's Avatar
2024 23' Flying Cloud
San Antonio , Texas
The iPhone 5 with the latest update has a bubble level built into the compass app under "Utilities". Bring up the compass, calibrate it by rolling the little ball around, and then swipe the screen. Voila, bubble level. I put it inside the door to set the side to side level, and then put it on the trailer tongue and work the jack to level it in that dimension. Done.
Cannonball is offline   Reply With Quote
Old 02-16-2014, 08:06 PM   #11
Ag&Au's Avatar
If I were using something that expensive to perform such a simple job, somewhere in that sequence of steps would be, "drop in the mud puddle in the dark".
Ken
Old 02-16-2014, 08:09 PM   #12
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I placed the round level on my iPhone on the grill on the top OB the stove. Then leveled the trailer, then adjusted the external level. The is will be close enough for fridge and oil and eggs will not run to the side of the frying pan.
Works for me.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 02-16-2014, 08:25 PM   #13
Cannonball's Avatar
San Antonio , Texas
I failed to mention that I use my wife's iPhone for this task. Mine is in the cupholder in the truck.
Old 02-16-2014, 10:08 PM   #14
Attachment 205715
That level has had the same problem, from the first day one was ever installed, many many years ago.
The sun heats up the glass, causing the fluid to leak out.
That then becomes the end of the level.
Reese at one time, had a two unit level that was installed on the A-frame, and was calibrated to the cooling plate in the reefer. But it's now NLA.
Actually, the real purpose of the level is not to level the trailer, but to level the reefer so that it would cool properly.
Andy Rogozinski
Inland RV Center
Corona, CA
Newbie dumb question re sewer hookups Rich of SCal Waste Systems, Tanks & Totes 62 02-23-2012 07:12 AM
Newbie with question TheReeses 1965 - 1969 Overlander 1 01-21-2012 11:00 PM
Newbie 190 question jamana1 Classic Motorhomes 4 11-12-2011 06:50 AM
Newbie Dumb Question shebeen 1974 - 1977 Overlander 6 07-07-2011 01:51 PM
'nuther newbie AS question re: RV parks.. Gringo On The Road... 18 05-26-2011 07:47 PM
