Old 01-04-2007, 06:35 AM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Zinc anodes would protect it if the trailer was submerged in salt water. To be serious, it would only work if the entire surface of the trailer were exposed to a conductive layer of moisture. It might be moderately effective if you parked next to the ocean with it salt air for long periods. The galvanized steel fasteners serve this purpose untill the loss all their plating and start to rust. I personally still like stainless that do not require periodic replacement.
The pictures are from a trailer parked in the salt air for many years.
ID:	30394   Click image for larger version
Old 01-04-2007, 06:57 AM   #16
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
more damage
check out how severe teh damage was to the tail light area on my globetrotter!
the aluminum under the rusted away light area crumbles in your hand. it's actually caused the aluminum skin to bubble on itself, so i'm replacing the entire rear quarters, and putting the tail lights inboard (where they should be, in my opinion!) ha!
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 09-12-2009, 10:21 PM   #17
1977 Argosy 28
Chambersburg , Pennsylvania
This is an extremely interesting thread since I am considering an Argosy that was parked 10 miles from the ocean for less than 10 years. What else besides fresh water washings can I do to neutralize any residue salt air salt mist? Anything metal will be examined closely!
Al's cousin
Al's cousin is offline   Reply With Quote
Chemical reaction? silver 67 Exterior Restoration Forum 26 05-29-2006 10:14 PM
What about seaside salt air? 26.982 amu Winterizing, Storage, Carports & Covers 26 01-31-2006 07:40 AM
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
galvanic corrosion teemack Ribs, Skins & Rivets 3 07-22-2004 12:22 AM
corrosion under lites Chas Ribs, Skins & Rivets 4 05-18-2003 08:57 AM
