Old 02-08-2012, 01:54 PM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Furnace covers / patches - How did you do it?
I replaced my Bowen water heater and I kept the original cover on my 64 overlander. (Still in progress, but I was able to get a 10 gallon tank in there finally - I want to post pics when I'm done)
I need to do something similar to the furnace. I am having trouble finding furnace mods by folks to keep them original. Can anyone help provide links? The PO used silicone to seal it, so I'm going to have to do some work to patch the original hole. I already ordered a sheet of Allclad.
robwok is offline   Reply With Quote
Old 02-08-2012, 02:05 PM   #2
Central , Mississippi
Here is what I did
http://www.airforums.com/forums/f109...ml#post1068678
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-08-2012, 02:21 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Are you putting in a new furnace and just want the exterior to look the same? I took my old furnace out, did not replace it, and used the original exterior exhaust shroud with a piece of waffle-aluminum underneath it to seal the hole. Can you post a pic of your situation?
tphan is offline   Reply With Quote
Old 02-08-2012, 02:49 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Tphan, I actually have the situation based on the link just above yours by HiHo. Same ugly double rivet situation, but much older setup for the heater. I'm torn between reinstalling the furnace and getting a top mounted heat pump. The problem is that with a heatpump, I wouldn't have heat when boondocking, and when docked, wouldn't have heat once it gets really cold unless I get the electric strip.
My trailer has a waffle shroud that went over the furnace exhaust. I think I can still use that but moved over. My main concern was how to do the patch. I kind of like the trim tht HiHo used, but really wanted it to look as original as possible.
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 08:15 PM
Furnace Problem Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-05-2011 06:30 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
