Old 07-04-2016, 08:34 AM   #1
1974 27' Overlander
North Granby , Connecticut
Question Front window support
Hi All, Have a little problem with the front window support system. One of the previous owners lost the front window cut out the horizontal supports so he could install a different window. After some time he found the original window and just safety wired it into place. Now comes the hard part is that a critical structure point in the front and can it be patched repaired by splicing in a filler peace or should i replace the hole rib. Photos to follow
Photo 108 is Road side
Photo 107 is Curb side
ID:	265924   Click image for larger version
ID:	265926   Click image for larger version
Big G is offline   Reply With Quote
Old 07-07-2016, 01:58 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Splicing would work. The window sections are not tied into the floor sections like the side ribs are. They really just support the windows. I would rivet and splice unless you have access to new ribs.
Matt
rugjenkins is offline   Reply With Quote
Restoring window support rods TxDave Windows, Doors, Locks & Vents 8 01-19-2016 08:03 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Front Window Support arm pickerdd Windows & Screens 2 03-20-2012 05:53 AM
Proper Front Support Point for Chassis guy99 Mechanics Corner - Engines, Transmission & More... 2 10-05-2004 05:54 PM
