Old 05-09-2015, 06:25 PM   #1
1964 24' Tradewind
Enumclaw , Washington
Front trim along bottom--repairing
I caught the front trim--pulled it loose when backing up and pulled out a few rivets and tore a bit of the underlying aluminum.
Question is: I can bend the torn pieces back in line and replace the rivets but should I fill behind the space with Sikaflex or just leave it dry?
Thanks in advance.
Jim Wolfe
wolffullmoon is offline   Reply With Quote
Old 05-09-2015, 06:54 PM   #2
Mixter's Avatar
1976 27' Overlander
Pics?
Mixter is offline   Reply With Quote
Old 05-09-2015, 09:03 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Fill the rivet holes with Sikaflex. It can't hurt & will prevent any leaks that may occur.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-10-2015, 05:13 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
Actually, I would use Tempro in the holes if you have it. I like it better than sikaflex....
Becky
1964 Bambi II
1988 Avion 32S
Old 05-10-2015, 10:36 AM   #5
jackson center , Ohio
Newer trailer or vintage?
Schu is offline   Reply With Quote
Old 05-10-2015, 11:42 AM   #6
1964 24' Tradewind
It is a 1964 Trade Wind
Old 05-10-2015, 01:27 PM   #7
1964 24' Tradewind
Pics for repait info
Having a terrible time posting pictures.
Any suggestions?
Repairing Vinyl covered trim... Kit tested. Keyair Classic Motorhomes 0 08-12-2012 01:18 PM
Repairing Main Door Holdback latch and blue trim Bugjuice Doors & Locks 5 09-16-2006 09:37 AM
Type of aluminum on the bottom front? sequoiacoast Belly Pans & Banana Wraps 7 05-19-2006 09:32 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
