Old 11-04-2006, 06:35 PM   #1
shinybean's Avatar
1964 22' Safari
1969 25' Tradewind
Greenville , South Carolina
Frame slicing through skin on 1960 Safari
Hi everyone,
I am new to this forum and Airstreams in general. I am looking to buy my first AS. We recently looked at a 1960 Safari. On the sides of the trailer, at the bottom, the frame appeared to be slicing through the skin. It was not on the belly pan, but on the outside. (Could be seen without getting under the trailer). Are these the Ribs coming through? Is this a major issue in terms of value, and ease of repair? Also, will this cause me additional problems down the road? Any help would be appreciated. Thanks!
shinybean is offline   Reply With Quote
Old 11-04-2006, 06:49 PM   #2
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Without seeing pics or being familiar with 60s unit construction, I'd guess that it's the outriggers. They are 14" wings that extend outward from the main frame rails to support the floor and shell.
See pic
Over time, excessive vibration (unbalanced running gear) probably causes this (as well as any kind of floor/frame separation).
Yes, it could be a problem as it could indicate unequal movement between the frame and the shell (separation, etc.).
Banana wrap repair, while not hard, is not fun.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-04-2006, 07:07 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
As Pizzachop pointed out it can be several things. Another possibility is a broken out rigger. If there is more than one I would suspect some major floor rot and the shell is moving a lot more than it should. On the 60's vintage trailers the "banana wrap" is not a seperate piece, the side sheets actually extend down to the belly pan. Derfintely fun to work on
Aaron
WBCCI #XXXX AIR #2495
Old 11-04-2006, 07:13 PM   #4
shinybean's Avatar
1964 22' Safari
1969 25' Tradewind
There was definitely more than one showing. I think there were about 8 or so. I'm not sure if I'm ready to put that kind of work into it yet I'd still like to be able to actually use it for it's intended purpose...I guess the search continues. Thanks to everyone for the tips!
Old 11-04-2006, 07:15 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
One other thing it may be is the bottom edge of the outrigger can be be so rusted that the smooth bottom curve is gone leaving a razor sharp edge to cut through the skin.
'77 Sovereign Intl 31' CB
Old 11-04-2006, 07:24 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Before the mid 60's, the belly sides are actually separate pieces. However, they are wrapped into the floor channel, so without removing the shell, it is almost impossible to repair this.
The outriggers had sharp edges back then, not the crimped ends lie the newer trailers have. Airstream installed a thin, vertical strip of aluminum in the belly wrap, in the exact places where the outriggers run, to avoid rub-through.
I am going to assume that if it is rubbed through in more than one place, there are serious issues, or extremely high mileage on this trailer.
Uwe
www.area63productions.com
Old 11-04-2006, 08:11 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
This thread might be helpful if you're looking.
Airstream Buying Advice
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-04-2006, 09:14 PM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Our Overlander has four or five of those spots in the banana wrap where the outrigger has worn through. I installed new tires before we moved the trailer (the old tires were beyond terrible), and now have several thousand miles on the trailer, with no further degradation of the banana wrap. So, those spots are not the kiss of deathe for an Airstream, they just bear watching, and eventually they will need to be taken care of. Since they have not gotten any worse, they are not that high on my personal list of things to repair. I am guessing the culprit was the bad tires.
Old 11-08-2006, 12:10 PM   #9
Outriggers
Outriggers have an edge that is only .070 inched wide.
It will cut through the underbelly with the greatest of ease.
The cause?
Lack of proper running gear balance will do it every time, guaranteed.
Old 12-03-2006, 12:18 PM   #10
shinybean's Avatar
1964 22' Safari
1969 25' Tradewind
Thanks for all of the help!!!
Safari Availability JLD 1974 - 1979 Safari 4 09-12-2002 08:32 AM
Looking for ideas on a sofabed for my Safari Scotti General Interior Topics 0 09-03-2002 01:45 PM
Purchase of 73 safari april Our Community 11 09-01-2002 01:33 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
