Old 02-01-2010, 10:39 AM   #15
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Here is another source for a bead roller I just found,
Bead Roller
Mittler Brothers Electric Beadroller
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 02-01-2010, 11:11 AM   #16
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I dont know why I waited so long to do a project. This is an awesome community.
tinman54 I am glad to hear you have this tool, I have the feeling I may be interested in your assistance with this. I have started to get an understanding of what will be required to fabricate the end segments and would like to do it right. We will be talking in the near future. Glad to see your post! And thank you again.
Hi Kay what type of project are you working on? I am interested in talking.
I hope I can add something of value here, I sure have gained alot.
Im looking forward this!
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-01-2010, 04:48 PM   #17
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Brad,
Just to confuse you (as several people have pointed out), I’ll reply instead of Kay.
Last winter, about this time (well, right after the annual RV show at the Minneapolis Convention Center), is when we started looking for our AS. Found one in Mobile, AL in 2 weeks, and then, just like you, had to wait until Spring before we could go get her and bring her home. Sometimes, these MN winters are just too dang hard to put up with!
We have our 1972 31’ Sovereign, lovingly called Little Girl. Here’s our thread on what we’re doing, which is a complete Refurb: http://www.airforums.com/forums/f185/little-girl-refurb-50967.html.
Last year was spent doing all the deconstruction, and finally starting the reconstruction. That was a great turning point!
Chris
Old 02-01-2010, 07:40 PM   #18
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Segments
Hi Brad, Tried a couple samples today after work with some galvanized metal. After looking at the airstream there really is not to much of a bead on the edge but the bead roller or just a bend with the break both look pretty good.I shot a couple pictures but hard to get a good shot. Should be able to make something work when the time comes.
Name:	airstream segments sample 002.jpg
ID:	95344   Click image for larger version
Name:	airstream segments sample 008.jpg
Name:	airstream segments sample 011.jpg
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 02-01-2010, 07:52 PM   #19
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
BradS----Pexto roller is expensive, new--but I found a tin-knocker who had extras--I bought one just like the above one pictured for 300.--good luck----jim
jamesardis is offline   Reply With Quote
Old 02-01-2010, 08:19 PM   #20
BradS's Avatar
1957 26' Overlander
Images: 14
tinman I didn't know how lucky I was going to be with this purchase. I look forward to seeing the results of your test bends.
My wife is dying to come out and see the trailer, we may request to make a social call in the near future.
Just a slight bend would seem to make fabricating panels easier.I look forward to getting one or two old segments off and seeing if the edges are straight or are they cut in a slight radius. I will stay in touch
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-02-2010, 07:16 AM   #21
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Here's one picture of your front end cap Brad. As you know, the snow is covering the worst of the damage. The bead is pretty obvious in this shot, although it is not a close up. Doug's test beads look pretty darned good for a first cut.
(P.S. I special shout out on the blog this past Sunday. Congrats again!)
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 02-02-2010, 07:30 AM   #22
BradS's Avatar
1957 26' Overlander
Images: 14
Thank you Tim
You made this possible. Ill let you know in a year or two if thats a good thing or not.
Dougs test beads do look good. I have been doing alot of reading and am starting to understand what I am up against. I guess its good I dont watch much TV. I know where my time will be spent.
Its hard not having the trailer here.
Jennifer has already named her. The Ms Holly Golightly. Holly G for short
Our other trailer is the Ms Glory B
I didn't post any pics yet cause she isn't home yet and I am not sure how, guess I need to work on that
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-02-2010, 08:07 AM   #23
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
In the Quick Reply, Click on "Go Advanced", and then click on the Paper Clip Image (next to the white smiley face).
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 02-02-2010, 08:14 AM   #24
BradS's Avatar
1957 26' Overlander
Images: 14
Not sure if this will work I think it might. This is a photo of the new project
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-02-2010, 08:39 AM   #25
BradS's Avatar
1957 26' Overlander
Images: 14
The first photo shows part of the blemish on the front .I will probably end up replacing most of the segments on this end cap. The back of the trailer has also been damaged by a tree or something from above.
The second photo shows the blemish in back. It will require a little less attention.
Work is slow right now and its getting hard to sit here without the trailer. I might need to open some windows and see if I can melt some snow
ID:	95372   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-03-2010, 11:17 AM   #26
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Holly G can come out of hibernation this weekend with the help of John Deere(a close neighbor of mine) if you have a place for her. Come on out anytime.
Old 02-03-2010, 11:51 AM   #27
BradS's Avatar
1957 26' Overlander
Images: 14
I would like that but I need to wait at least a couple weeks yet. I need to figure out where to park it till I can get it into the back yard. As well , the money needs to sit just a little longer.
We, Jennifer and I may be interested in stopping by Saturday afternoon so she may see it. Let me know if that would be ok, if so Ill need your address. I didnt seem to pay to much attention to directions last time I was out.
The more I read on the forums the more I am looking forward to this project.
Nothing seems beyond reach!
The photo is part of what I did to our current trailer
WBCCI 10289
TAC MN-69
AIR 11240
Old 05-18-2010, 02:04 PM   #28
Hi BradS!
I am glad I finally got to see pictures of your new "project". That is going to be one good looking trailer once it is done!
BambiMPLS
BambiMPLS is offline   Reply With Quote
'61 Bambi Exterior Segments flyrc 1961 - 1963 Bambi 1 11-28-2009 12:37 PM
2 panel end caps??? byamcaravanner Off Topic Forum 1 02-03-2008 09:34 AM
Condensation Forming in Diesel Tank B&J Tow Vehicles 20 12-10-2007 05:40 PM
Forming a new WBCCI Unit jimmickle WBCCI Forum 4 04-10-2007 07:03 PM
Cracks forming on shell --- Repair Help !!! SlammaJamma Ribs, Skins & Rivets 3 05-26-2005 10:22 AM
