Old 08-09-2014, 08:27 PM   #1
merrypaws's Avatar
1976 25' Tradewind
xxxx , Delaware
Fix for skin cracks?
My 76 tradewind has a crack on each front corner. Almost looks like someone jack knifed each side because they are in the same location. A PO put silver alum tape oveR them on the outside . I have the walls removed on the inside and I can see the cracks. Is there anything I can do to the inside to seal it? Is there a less ugly solution for the outside since replacing the panels is definitely not a financial option right now.
Name:	ImageUploadedByAirstream Forums1407633962.325062.jpg
ID:	218734Click image for larger version
Name:	ImageUploadedByAirstream Forums1407633978.365234.jpg
ID:	218735Click image for larger version
Name:	ImageUploadedByAirstream Forums1407634044.069448.jpg
merrypaws is offline   Reply With Quote
Old 08-09-2014, 08:35 PM   #2
1981 31' Excella II
New Market , Alabama
I would rivet a new panel that looks like a guard to cover the whole area. An ear shaped thing. It would give it symmetry. You could also just put some of those stainless guards over the corners to cover up the patch.
I am wondering what caused this crack. Any other structural damage? It looks like a fatigue crack but if that were the case it would run from an edge. There is no load in that area that would cause that. Was there a dent associated with the crack?
Perry
Old 08-09-2014, 08:38 PM   #3
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Probably best to replace the panels. I think they are just plain old aluminum, not shaped like the end caps ?....so would be relatively cheap to do it. Or make some decorative patches and rivet them in place.
arktos55343 is offline   Reply With Quote
Old 08-09-2014, 10:14 PM   #4
2002 19' Bambi
Lafayette , California
A prior owner drilled the ends of the cracks to stop them from cracking further. That seems to have worked and suggests that whatever caused the cracks has not continued.
I don't think you can cheaply replace the panels because they look to have compound curves. Patching with small matching (on the two sides of the trailer) aluminum patches riveted in place might look best. You might consider a patch both inside and outside with caulk/sealant in between.
Tim
Tim A. is offline   Reply With Quote
Cracks in skin yve79 Ribs, Skins & Rivets 16 10-13-2011 12:17 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 09:38 PM
Stress Cracks in the Skin! swebster General Motorhome Topics 12 10-13-2005 08:27 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 08:50 AM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 01:42 PM
